Author Topic: HHKB Lite 2  (Read 1509 times)
Offline jameslr
HHKB Lite 2
« on: Mon, 26 August 2013, 13:56:30 »
I'm not sure if this is a good deal or not since it's really just a membrane keyboard with the HHKB layout, but for those interested in seeing if they would like the layout without the $260+ investment it might be worth a shot.
http://www.ergonomicsmadeeasy.com/store/mini-keyboards/product/happy-hacking-lite-2-keyboard/
$66 (+shipping?) is considerably cheaper than the other sources I've found on the usual channels (Ebay, Amazon, etc.)
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline randompony
Re: HHKB Lite 2
« Reply #1 on: Mon, 26 August 2013, 14:07:12 »
I think i found it last week for $45 or something but I would have to check again.
and also apparently the lite is not even close to the topre feeling (rather get an old dell quiet key)
Offline Xenderwind
Re: HHKB Lite 2
« Reply #2 on: Mon, 26 August 2013, 14:11:57 »
lite versions are just regular rubber dome membranes I believe.  not topre
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Re: HHKB Lite 2
« Reply #3 on: Mon, 26 August 2013, 15:48:08 »
Still way overpriced for a membrane keyboard.
Re: HHKB Lite 2
« Reply #4 on: Mon, 26 August 2013, 17:27:26 »
Like jameslr said, it is not Topre but is a cheap option ifd you want a HHKB but don't know whether you would be able to use the radical layout that it has.
Actually this is slightly closed to the FC660x in that it has arrow keys too, which the HHKB Pro 2 lacks.
