Author Topic: What switch is this?  (Read 1689 times)
Offline abdulmuhsee
« on: Mon, 26 August 2013, 20:31:57 »
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: What switch is this?
« Reply #1 on: Mon, 26 August 2013, 21:40:27 »
Some rubberdome with and Alps mount slider.
Offline abdulmuhsee
« Reply #2 on: Mon, 26 August 2013, 22:29:05 »
And here I thought it was mechanical :-/.
« Reply #3 on: Mon, 26 August 2013, 22:54:02 »
Slider with MX or Alps mounts are pretty common on older rubberdome. It was good for them to be able to take advantage of existing keycap sources. Later on they started more often to integrate the slider and keycap into one piece.
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #4 on: Tue, 27 August 2013, 18:38:58 »
Are those doubleshots or dyesubs? Sell on the keycaps :)
Bore Awards
  • RIP
    • Boring twaddle
« Reply #5 on: Tue, 27 August 2013, 18:44:27 »
To answer your other remark:
See how the slider shaft is part of the same plastic moulding as the plastic plate under the keycaps? That's a good sign that it's not mechanical: it means that the plate/case only exists to support sliders over the membrane sheets (typically with rubber domes between the sliders and membranes). Mechanical switches are typically discrete, i.e. you'll see physical switches soldered to onto a PCB, or mounted in stamped-out holes in a metal plate (though the plate is in rare cases also moulded plastic). Look at your own avatar: you can see the gaps between the plate and the switch module.
Bore Awards
