Author Topic: Razer Tournament & G81-3000 & G81-1800  (Read 2091 times)
Offline uzoc
« on: Tue, 27 August 2013, 12:23:44 »
Trying to decide which to get either the G81-3000 OR G81-1800 for keys (for my Razer Tournament).
Any recommendations regarding keycaps and stabilizers?
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Razer Tournament & G81-3000 & G81-1800
« Reply #1 on: Tue, 27 August 2013, 12:31:20 »
For razer board you will need Cherry keycap from at least 2 keyboard. You will need a set from something like a winkeyless 3000 which will give you the majority of needed correct size keys, and 1x keys from something like a winkey 1800/7000 which also has the right 6x size spacebar but the mounting is not the same. Also you will either need to stem mod stepped caps or get that from yet another board like an 8000 series.
Offline uzoc
« Reply #2 on: Tue, 27 August 2013, 12:44:57 »
OK, thanks.
The keyboards are the opposite (from what you recommended) winkey and (winkeyless).
OK, as long as I get the majority of the 1X's (37 at least).
So for the majority of 1X's, a WinkeyLess 3000 OR Winkey 1800?
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
« Reply #4 on: Tue, 27 August 2013, 13:54:29 »
For alphas it doesn't matter really where you get them, all G80/G81 use the same 1x keys so whatever is best condition for lowest price. Whatever additional keys are going to mostly be the same as well like backspace, return and such. Only the bottom row keys are different, so if you can find one that covers more then I would go with that choice. Those qwerkeys set for modifiers could be a way to go as well, would just need and extra 1x key to match for a menu key.
Offline uzoc
« Reply #5 on: Tue, 27 August 2013, 15:21:21 »
