Author Topic: .  (Read 3124 times)
Offline esoomenona
  • Gnillort?
« on: Tue, 27 August 2013, 14:25:31 »
« Last Edit: Fri, 17 October 2014, 10:16:22 by esoomenona »
Offline alaricljs
  • I be WOT'ing all day...
Re: 60% M13
« Reply #1 on: Tue, 27 August 2013, 14:33:28 »
There is mention in Hasu's tmk of trackpoint support....
Filco w/ Imsto thick PBT
Offline esoomenona
  • Gnillort?
« Reply #2 on: Tue, 27 August 2013, 14:51:35 »
« Last Edit: Fri, 17 October 2014, 10:16:14 by esoomenona »
Offline wcass
Re: 60% M13
« Reply #3 on: Tue, 27 August 2013, 18:27:35 »
for TKL, you can get away with folding the membrane. you could even go 75% (no tenkey and no navigation) with just a single fold. but a real 60% (no tenkey, no nav, no function) pretty much requires custom or modified membranes because two folds always seems to cause ghost keys or other failure.
if you want to go 60%, you might read my thread on custom BS membranes.
http://geekhack.org/index.php?topic=40111.0
Hasu did the code for my M60 so it should not be difficult to add trackpoint support.
Offline esoomenona
  • Gnillort?
« Reply #4 on: Tue, 27 August 2013, 19:04:50 »
« Last Edit: Fri, 17 October 2014, 10:16:03 by esoomenona »
