Author Topic: FC660C caps lock light.  (Read 4304 times)
Offline AuRinBei
« on: Wed, 28 August 2013, 18:49:43 »
I finally got my FC660C. It's my first Topre, and I'm liking it so far.  But I noticed that when you switch Caps Lock to Ctrl, pressing Ctrl doesn't turn on the Caps Lock light. I don't know if this is a defect of if it is intended to work this way. Can anyone tell me if there's does the same thing?
87u || Poker 2
Offline bueller
  • MX baller
  • Church of the Ergo Clear
Re: FC660C caps lock light.
« Reply #1 on: Wed, 28 August 2013, 19:10:16 »
That's the way it should work IIRC.
Offline AuRinBei
« Reply #2 on: Wed, 28 August 2013, 19:15:18 »
It's weird that the alternate Ctrl key has a light thing then. What is that for, the people who like to be rebels but are really used to pressing Ctrl in the corner?
87u || Poker 2
Offline bueller
  • MX baller
« Reply #3 on: Wed, 28 August 2013, 19:26:41 »
Well one way to tell for sure is to check if there's an LED in the usual CTRL position, if there is then maybe I'm wrong and there is a problem with your board.
Offline AuRinBei
« Reply #4 on: Wed, 28 August 2013, 19:38:27 »
No, there is no light down there. I figured it would be like a Ducky, where if you hit the key currently designated as caps lock, it turns the caps lock light on.
87u || Poker 2
Offline jabar
« Reply #5 on: Wed, 28 August 2013, 19:43:40 »
My F660C works the same way: no Caps light after flipping the DIP switch setting. I have a feeling that if you use AutoHotkey it will work though, which kinda defeats the whole purpose of that DIP setting.
So, not a defect, but a feature!
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline AuRinBei
« Reply #6 on: Wed, 28 August 2013, 20:00:30 »
lol it does. What a ridiculous switch. I'll use it for work then, but at home I use AutoHotkey anyway.
87u || Poker 2
