Author Topic: Dye Sub?  (Read 3143 times)
Offline TheeCOoon
Dye Sub?
« on: Thu, 29 August 2013, 23:20:42 »
Anyone know what dyesub is and why it is favorable?
Offline kenmai9
  • Unicornforce
  • Skrrr
Re: Dye Sub?
« Reply #1 on: Thu, 29 August 2013, 23:22:07 »
Dye sublimation is a process where heat is used to impregnate a material with a dye. This is different to printing in that printing forms a layer of paint on top of the plastic, whereas dye sublimation causes the dye to sink into the plastic. Dye sublimation was a popular method for keycap printing in the 1980s and 1990s. Because the dye permanently stains the plastic, it cannot be worn off like paint, and unlike laser printing, it can be used to easily print a mixture of different colours.
Source: http://deskthority.net/wiki/Keycap_printing
Offline TheeCOoon
Re: Dye Sub?
« Reply #2 on: Thu, 29 August 2013, 23:25:04 »
OOOOOh so the keys fade much slower than just normal printing?
Offline kenmai9
  • Unicornforce
  • Skrrr
Re: Dye Sub?
« Reply #3 on: Thu, 29 August 2013, 23:27:15 »
Well dye sub is "permanent" so it shouldn't ever fade. Pad printing and laser are both added to the top of the key cap, so it's possible to rub it off over time due to erosion. Dyesub bakes it into the plastic so it doesn't fade. Doubleshot keys also don't fade because the legends are plastic :) take a look at the source I sent and you'll see the other types.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Re: Dye Sub?
« Reply #4 on: Thu, 29 August 2013, 23:28:57 »
Maybe instead of making threads for every thought you have, you could consolidate it into one.  Or look into the easily available resources that would answer all of your questions without you making a thread at all.
Or you could just be padding your **** to try and dump something in the classifieds.
Offline TheeCOoon
Re: Dye Sub?
« Reply #5 on: Thu, 29 August 2013, 23:30:34 »
Yes Sir!!!!
Offline danny
Re: Dye Sub?
« Reply #6 on: Fri, 30 August 2013, 05:37:38 »
Well, somehow you have to get to your 60 posts, don't you? :))
Joking aside much of what the OP asked is easily researchable on the internet. Two seconds on Google would have revealed what dye sublimation is.
WASD v2 TKL Blue
