Author Topic: Asian Ducky tkl  (Read 1860 times)
Offline altern4tivepl4n
Asian Ducky tkl
« on: Fri, 30 August 2013, 11:11:04 »
Hey guys, sorry if this was asked before but i couldn't find any information about it. I was looking into getting a Ducky dk9087 as my first mech and i saw this link: (http://global.pchome.com.tw/english/?mod=item&func=exhibit&IT_NO=DCAH0X-A70702660&SR_NO=SBAE3W&ROWNO=6&tm=e). I was wondering if there was any difference between the functionality of the Asian one and the full English one (http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=168). The only difference are the keys right (excluding switches)? But for all normal purposes it's the same?
Offline Obakemono
Re: Asian Ducky tkl
« Reply #1 on: Fri, 30 August 2013, 11:19:33 »
Same model so, there should be no difference.
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Asian Ducky tkl
« Reply #2 on: Fri, 30 August 2013, 11:19:56 »
Only difference is in the legends on the keycaps. OS does not know what is printed on the keycap, only how many keys there are to assign to whatever regional keyboard layout you have active.
Offline berserkfan
Re: Asian Ducky tkl
« Reply #3 on: Fri, 30 August 2013, 11:46:37 »
Ivan, is that true of all keyboards? So if I buy a German layout keyboard, but swap the keycaps for US-ANSI and use the keyboard on a Windows-US layout, will it work normally?
(As you can guess, I have been asking you lately about German-made Cherrys.)
Re: Asian Ducky tkl
« Reply #4 on: Fri, 30 August 2013, 11:56:56 »
Yes. Sometimes I will roll with other languages like German, Swiss or even French keycaps set for lols, but I don't change my keymapping in the OS. Keyboard sends a scancode, the OS assigns a meaning to that scancode with keyboard layout. The keycap legends are irrelevant if you don't have the matching keymapping loaded.
Right now you could go change your keymap to German and on your US ANSI keyboard if you type the [ key you will get the Ü.
« Last Edit: Fri, 30 August 2013, 11:58:54 by IvanIvanovich »
Re: Asian Ducky tkl
« Reply #5 on: Fri, 30 August 2013, 15:00:40 »
thank you all for the quick and informative replies! My wasd sampler should come in today and i'll go from there! :)
