Author Topic: HHKB Pro in Yahoo auctions japan.  (Read 2784 times)
Offline Obakemono
« on: Fri, 30 August 2013, 11:39:34 »
Hi!
I was checking Yahoo auctions Japan for HHKB Pro and you can find some really neat offers.
http://auctions.search.yahoo.co.jp/search?p=happy+hacking&auccat=&aq=-1&oq=&ei=UTF-8&slider=0&tab_ex=commerce
Does anyone know a good proxy working with yahoo auctions?  :D
Would be great to buy a HHKB for only 80$  ;D
Offline jameslr
Re: HHKB Pro in Yahoo auctions japan.
« Reply #1 on: Fri, 30 August 2013, 13:30:17 »
This is the original PFU HHKB - it's a membrane keyboard not Topre capacitive. They didn't start making Topre capacitive boards until the HHKB Professional was released. It's still probably a nice piece of history, but not worth $80 IMO.
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline Obakemono
« Reply #2 on: Fri, 30 August 2013, 13:35:32 »
Ups, didn't knew, you have a Pro 2 in 12000 yens which is still nice.
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #3 on: Fri, 30 August 2013, 13:36:39 »
I'd really like a Pro 1 but they can be tricky to find, check the wiki OP to ID model numbers.
http://en.wikipedia.org/wiki/Happy_Hacking_Keyboard
Offline Obakemono
« Reply #4 on: Fri, 30 August 2013, 13:53:22 »
Well then, according with wikipedia it is indeed a Pro 2 with Topre capacitive switches.
Offline jameslr
« Reply #5 on: Fri, 30 August 2013, 14:05:02 »
No, the title of the auction says model number: PD-KB02.
On Wikipedia this is listed under the Membrane keyboards - one of the original HHKBs. It's not a Pro.
Offline Obakemono
« Reply #6 on: Fri, 30 August 2013, 14:13:30 »
http://page9.auctions.yahoo.co.jp/jp/auction/k168882333
^ This $80
Offline jameslr
« Reply #7 on: Fri, 30 August 2013, 14:20:29 »
Nice, if you could get it for that it would be a steal. Likely, as with all auctions, there will be a bidding war in the last 10 minutes.
