Author Topic: Does anyone know about this weird IBM keyboard?  (Read 2357 times)
Offline berserkfan
« on: Fri, 30 August 2013, 11:44:46 »
http://www.ebay.com/itm/IBM-KEYBOARD-104-KEY-DATA-ENTRY-P-N-09F4231/111153393455?_trksid=p2045573.m2102&_trkparms=aid%3D555012%26algo%3DPW.MBE%26ao%3D1%26asc%3D17058%26meid%3D937152022009521335%26pid%3D100034%26prg%3D7917%26rk%3D3%26rkt%3D8%26sd%3D181206314850%26
This guy isn't a buckling spring, if any of you are wondering. It's a weirdo-weird. I've only seen this layout on Kishy's blog before. Any information on the switches? And layout? And usage? Let's hear it for the collective Geekhack wisdom!
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
Re: Does anyone know about this weird IBM keyboard?
« Reply #1 on: Fri, 30 August 2013, 12:04:01 »
I REMEMBER WHEN ONE OF THOSE POPPED UP A FEW YEARS AGO. IF I REMEMBER RIGHT THEY HAD RUBBER DOMES IN 'EM.
Offline Thimplum
  • Master of all Ponies
« Reply #2 on: Fri, 30 August 2013, 12:15:29 »
That layout looks pretty cool. It's too bad that it's rubber dome...
TP4 FOR ADMIN 2013
Offline Tarzan
  • formerly known as Greystoke
« Reply #3 on: Fri, 30 August 2013, 12:42:42 »
New in box, eh?  That's pretty cool, for something made in 1990...
The lower pictures (an actual ebay ad with good pictures!  Yowza!) show some with the caps off, they do look like rubber dome sliders.  Also this descriptive text:
104-KEY Soft Touch
Offline berserkfan
« Reply #4 on: Fri, 30 August 2013, 15:32:46 »
well, apart from the rubber dome alphs, it seems some keys look a bit like Cherrys except they are not. Wonder what they are and why you would use two types of switches on the same keyboard.
Also wonder about the keycaps. They're very weird.
Offline bazemk1979
« Reply #5 on: Fri, 30 August 2013, 16:22:39 »
rubber dome, someone bought it and made it work with soarer.
« Reply #6 on: Fri, 30 August 2013, 16:40:12 »
Its a normal ibm "data entry" layout. They actually made "data entry" layout keyboards for many of the models. I have a keyboard for a "model C" (model F technology) keyboard with this layout.
The rubber domes in this are by honeywell, I believe. These keyboards have been on ebay for a while.
It's a striking similarity to the "space unsaver:" 104 key model F, but you can spot the difference, as the F version has a "raised" part of the case all the way across, and does not "step down" past the 24 F keys as this does.
Offline ch_123
« Reply #7 on: Fri, 30 August 2013, 18:40:24 »
Rubber dome for the one of the later 3270-compatible terminals.
There are 104-key Model Fs, but they are quite rare.
My beam spring board has the same layout as those ones.
« Last Edit: Fri, 30 August 2013, 18:54:39 by ch_123 »
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #8 on: Fri, 30 August 2013, 19:25:46 »
These are special data entry keyboards, as the name implies. The layout was designed specifically for high volume, high CPS data entry for things like transcription, order entry, etcetera. The objective being to maximize the CPS of the keyboard by altering the layout. Which is why it's so weird. There's probably a bunch of RPQ'd layouts for differing systems, since these are almost exclusively found with TwinAx setups using S/370, S/390 and AS/400 so generally CRM, order entry, etc, on homegrown (in-house developed) systems.
Did it work? Hell if I know. But that was the logic behind the design. In theory, someone doing the data entry should be able to do so without ever moving their hands from the home row. In practice I really don't know.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
