Author Topic: Any Futaba / SMK Lovers Out There ?  (Read 4039 times)
« on: Fri, 30 August 2013, 21:21:00 »
So today I found a "Laser" keyboard at a salvage store and picked it up.
The keys feel very nice, light, tactile, clicky, overall very pleasant and MX-compatible doubleshots to boot.
Although it has the bigass Enter that I loathe, this seems like it could be a particularly nice board.
Plus, I have another donor board if I need to replace switches.
What is the consensus on these?
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
"The pure products of America go crazy"
- William Carlos Williams - "For Elsie" 1942
Re: Any Futaba / SMK Lovers Out There ?
« Reply #1 on: Fri, 30 August 2013, 21:45:46 »
I honestly didn't care for the Futaba switches I tried.
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #2 on: Sat, 31 August 2013, 02:21:41 »
I'm a fan of the SMK "Heavy" version which is found in the Lasers sometimes. Mostly it's found in later versions though, sadly. There is no ANSI layout version I'm aware of, but I may just not have seen it.
They are a bit on the fragile side as far as mounting.
BTW, if you haven't noticed yet, the keycaps are ABS but they are true double-shots and RIDICULOUSLY thick. At least on MOST of the examples I've found.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #3 on: Sat, 31 August 2013, 06:43:01 »
Wait — are these SMK or Futaba? They're quite different!
SMK Cherry MX mount
Futaba clicky switch
Note that they could hardly be any more different (for metal contact switches, anyway)
« Last Edit: Sat, 31 August 2013, 06:45:03 by Daniel Beardsmore »
Bore Awards
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #4 on: Sat, 31 August 2013, 09:09:10 »
i have the same laser board, easily one of my favorites!!
good pickup :thumb:
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #5 on: Sat, 31 August 2013, 09:10:24 »
SMK Cherry MX mount
never had apart- but possibly smk :-\
  • RIP
    • Boring twaddle
« Reply #6 on: Sat, 31 August 2013, 09:17:23 »
It's fairly obvious which it is from simply pulling a keycap!
Bore Awards
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #7 on: Sat, 31 August 2013, 12:18:42 »
 :eek:
smk..............sorry
« Reply #8 on: Sat, 31 August 2013, 15:10:53 »
SMK Cherry MX mount
Sorry, I thought that they were very similar.
Both keyboards have second generation SMKs. I like the feel a lot, but a bigass Enter is just about a deal-killer for me anymore.
One board has several dead keys scattered around it, so I plan to harvest the switches. Are they compatible with anything else?
I may use the Laser for a bit, but I feel sure that I will put it up for sale soon. Unless there is a way to harvest the switches and use them somewhere better!
  • RIP
    • Boring twaddle
« Reply #9 on: Sat, 31 August 2013, 15:12:37 »
So far as I know, no, they're not compatible with any non-SMK switches. Pity, as they're good switches.
Bore Awards
