Author Topic: Where do i edit the wasd v2 87 key version?  (Read 1891 times)
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« on: Fri, 30 August 2013, 22:40:42 »
I can't seem to locate a place to enter custom keys and such, if anyone can show me or point it out that would be fantastic, and on a side note anyone here that has a wasd keyboard what do you think of it?
Offline gnubag
Re: Where do i edit the wasd v2 87 key version?
« Reply #1 on: Fri, 30 August 2013, 22:44:55 »
http://www.wasdkeyboards.com/designer/index.php?action=main&model=model-87&case=v2
instructions are at the bottom
and there should be a thread about the v2 somewhere here.
Offline Air tree
« Reply #2 on: Fri, 30 August 2013, 22:52:21 »
I was refering to the key legend custom-izer i can find the colour cap ones but i can't seem to find the custom key cap editor for the legends and such.
Offline EvanA
    • Personal Website
« Reply #3 on: Fri, 30 August 2013, 23:23:09 »
They removed the ability to do individual keycap customization with the v2.  Side note, I just got a v2 104 key with clears and it's amazing.  Great build quality and it looks very nice.
Offline Lu_e
« Reply #4 on: Fri, 30 August 2013, 23:37:57 »
You can still get individual custom keys but have to create the files yourself i think?
"...you can submit a custom layout file for more advanced designs.
If you are submitting a layout file, you will need to set the keycap colors with the Custom Keyboard Designer.
Layout File Downloads (Right-click, Save As to download.)
 - CorelDRAW
 - Adobe Illustrator
 - Inkscape
Read again: http://www.wasdkeyboards.com/index.php/wasd-v2-87-key-custom-mechanical-keyboard.html
Just say NO to ABS keycaps
Offline Air tree
« Reply #5 on: Fri, 30 August 2013, 23:56:06 »
Oh, well that was simple. thanks for pointing out that out haha!
