Author Topic: Lube for the stabilizers?(where can i get it)  (Read 2280 times)
Offline sor
« on: Sat, 31 August 2013, 15:41:44 »
Hi guys im looking for lube for the stabilizers, where can i get it? preferably around my area, maybe a local store(ace hardware/hardware shop)
ESPORTS!
Offline BlueBär
Re: Lube for the stabilizers?(where can i get it)
« Reply #1 on: Sat, 31 August 2013, 16:19:38 »
Search in a local hobby store, I used some for model cars. You don't really need something special for stabs.
Offline Phillip_J_Fry
« Reply #2 on: Sat, 31 August 2013, 16:20:36 »
I've used Liqui Moly Silicon-Fett
Offline Danule
« Reply #3 on: Sat, 31 August 2013, 18:43:58 »
If you cant find any around you elite keyboards sells some too
45g Brown Brown Blue
« Reply #4 on: Sat, 31 August 2013, 18:57:56 »
Superlube: Recommended by The_Beast and used by WASDKeyboards. I was told you could grab it at hardware stores or Home Depot.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #5 on: Sat, 31 August 2013, 19:57:57 »
dupont teflon silicone lubricant from lowes...........
$3.99
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline sor
« Reply #6 on: Sun, 01 September 2013, 01:28:23 »
is it used for those mini rc cars?
ESPORTS!
Offline BlueBär
« Reply #7 on: Sun, 01 September 2013, 01:55:38 »
Yes, but as I said you can use various lubes. Just get something that's available and not too expensive.
