Author Topic: Does best buy have mech keyboards i can try?  (Read 2221 times)
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« on: Sun, 01 September 2013, 09:56:59 »
Well i'm going out to lunch today with my family and that place is right next to a best buy and i was wondering does best buy have any mech keyboards? I was checking out their online site and it seems they have coolermaster, Das, and logitech, but i was wondering does that still translate over to their actual store?
Offline tehsprayer
Re: Does best buy have mech keyboards i can try?
« Reply #1 on: Sun, 01 September 2013, 11:36:47 »
The most they'll have are Razer blackwidows and steelseries 6gv2
REΛLFORCE 87U - uniform 55g
Offline Air tree
« Reply #2 on: Sun, 01 September 2013, 11:38:28 »
I guess that will at LEAST let me know if i like cherry mx blues.
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #3 on: Sun, 01 September 2013, 11:39:00 »
You might want to give them a call. They might have razer but not Das. Have you seen max keyboard cherry max switch set? It has mx blue, brown, black and red on a pcb. http://www.maxkeyboard.com/max-keyboard-keycap-cherry-mx-switch-o-ring-sampler-kit.html
Offline Air tree
« Reply #4 on: Sun, 01 September 2013, 11:45:04 »
Oh thank you! i didn't know max keyboard sold pcb mounted ones at a cheaper price than wasd that is not pcb mounted!
Offline Air tree
« Reply #5 on: Sun, 01 September 2013, 11:49:44 »
Oh after calling it seems they have the logitech g710+ and the razer blackwidow, both keyboards have the switches i'm looking at the most!
Offline danny
« Reply #6 on: Sun, 01 September 2013, 13:09:41 »
Don't make the same mistake as me and forget that the Logitech has o-rings preinstalled while the Razer does not :))
WASD v2 TKL Blue
« Reply #7 on: Sun, 01 September 2013, 14:18:09 »
If you're lucky enough to live near a MicroCenter, I would try there instead.
Offline Air tree
« Reply #8 on: Sun, 01 September 2013, 14:55:32 »
Well i'm back and i could only try the blackwidow a little bit but i couldn't try the g710+ because they wouldn't take it out of the box, but i have concluded that i love Cherry mx blues.
Offline danny
« Reply #9 on: Sun, 01 September 2013, 15:44:50 »
That was also my conclusion after trying out the Blackwidow at our local electronics market!
You probably won't be wrong with this decision  :thumb:
WASD v2 TKL Blue
