Author Topic: Code keyboard.  (Read 3672 times)
Offline C5Allroad
  • Formerly HUNTERANGEL121
Code keyboard.
« on: Sun, 01 September 2013, 21:09:58 »
Hey guys I looked at code keyboard and saw that it had Cherry MX clears and was wondering whether it had NKRO on usb or do you have to use PS2?
Offline HendyZone
  • HHKB Elite
    • MechanicalKeyboards.co.id
Re: Code keyboard.
« Reply #1 on: Sun, 01 September 2013, 21:12:16 »
True N-Key Rollover over PS/2 with included adapter
Offline C5Allroad
Re: Code keyboard.
« Reply #2 on: Sun, 01 September 2013, 21:15:37 »
Oh ok thank you. I'm still looking for a keyboard then, my motherboard doesn't have PS2 ports.
Offline dante
Re: Code keyboard.
« Reply #3 on: Sun, 01 September 2013, 21:17:25 »
Why do you need NKRO?
Offline rarar
  • moist booty seepage
Re: Code keyboard.
« Reply #4 on: Sun, 01 September 2013, 21:31:18 »
honestly dont bother looking for a keyboard with NKRO over USB, first off you'll never find one (unless they use some weird method to achieve that in which case it might be safer to NOT get it because it might have negative effects) But also the most you would ever need is probably around 6-8KRO unless you smash your entire forearm against a keyboard for a living.
Ỏ̷͖͈̞̩͎̻̫̫̜͉̠̫͕̭̭̫̫̹̗̹͈̼̠̖͍͚̥͈̮̼͕̠̤̯̻̥̬̗̼̳̤̳̬̪̹͚̞̼̠͕̼̠̦͚̫͔̯̹͉͉̘͎͕̼̣̝͙̱̟̹̩̟̳̦̭͉̮̖̭̣̣̞̙̗̜̺̭̻̥͚͙̝̦̲̱͉͖͉̰̦͎̫̣̼͎͍̠̮͓̹̹͉̤̰̗̙͕͇͔̱͕̭͈̳̗̭͔̘̖̺̮̜̠͖̘͓̳͕̟̠̱̫̤͓͔̘̰̲͙͍͇̙͎̣̼̗̖͙̯͉̠̟͈͍͕̪͓̝̩̦̖̹̼̠̘̮͚̟͉̺̜͍͓̯̳̱̻͕̣̳͉̻̭̭̱͍̪̩̭̺͕̺̼̥̪͖̦̟͎̻̰_Ỏ̷͖͈̞̩͎̻̫̫̜͉̠̫͕̭̭̫̫̹̗̹͈̼̠̖͍͚̥͈̮̼͕̠̤̯̻̥̬̗̼̳̤̳̬̪̹͚̞̼̠͕̼̠̦͚̫͔̯̹͉͉̘͎͕̼̣̝͙̱̟̹̩̟̳̦̭͉̮̖̭̣̣̞̙̗̜̺̭̻̥͚͙̝̦̲̱͉͖͉̰̦͎̫̣̼͎͍̠̮͓̹̹͉̤̰̗̙͕͇͔̱͕̭͈̳̗̭͔̘̖̺̮̜̠͖̘͓̳͕̟̠̱̫̤͓͔̘̰̲͙͍͇̙͎̣̼̗̖͙̯͉̠̟͈͍͕̪͓̝̩̦̖̹̼̠̘̮͚̟͉̺̜͍͓̯̳̱̻͕̣̳͉̻̭̭̱͍̪̩̭̺͕̺̼̥̪͖̦̟͎̻̰ ด้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็_ด้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็
Offline daerid
    • Rossipedia
Re: Code keyboard.
« Reply #5 on: Sun, 01 September 2013, 23:33:09 »
I still have not run into any situation where 6KRO was insufficient. Then again, about the only situation I can think of that might require it is stenography.
Offline C5Allroad
Re: Code keyboard.
« Reply #6 on: Sun, 01 September 2013, 23:37:04 »
Then you guys haven't seen me playing planetside 2 trying to do reverse maneuver :p  I know Corsair, Maxkeyboard, and Ducky can do NKRO, But I'm just looking for different choices.
Offline ComradeSniper
  • HHKB Pro
Re: Code keyboard.
« Reply #7 on: Sun, 01 September 2013, 23:41:17 »
What keyboard are you using right now?
Offline sth
  • 2 girls 1 cuprubber
Re: Code keyboard.
« Reply #8 on: Sun, 01 September 2013, 23:52:49 »
buying a keyboard with dubious input stats is not going to change your gameplay
Offline C5Allroad
Re: Code keyboard.
« Reply #9 on: Sun, 01 September 2013, 23:57:40 »
Using a K90 my cluster of keys Print screen page up/down don't work. So that's why I'm looking for a new keyboard.
To sth I know that buying a keyboard with amazing stats won't help my gameplay but when buying something why not "future proof"? My K90 lasted me 1 yr and a half now it's either Ducky or nighthawk X8
Offline rarar
Re: Code keyboard.
« Reply #10 on: Mon, 02 September 2013, 00:07:03 »
http://lmgtfy.com/?q=dubious
Offline C5Allroad
Re: Code keyboard.
« Reply #11 on: Mon, 02 September 2013, 00:10:04 »
Lol I didn't want to google it... But I think I'm set on Ducky. Is there a set of external media keys like there is for the numpad?
Offline Hellmark
Re: Code keyboard.
« Reply #12 on: Tue, 03 September 2013, 16:22:00 »
4 key is about the most I've ever really needed. I have done 5 once before, but that was more because I wanted to do something different (basically, had a global hotkey setup to lock my desktop if I hit control-shift-winkey-alt-z or basically mashing the lower corner of the keyboard).
A handful of games will hit 4 or 5. if I am doing a spiraled climb while targeting and firing at missles in BSGO, then I hit limits sometimes.
« Last Edit: Tue, 03 September 2013, 16:24:44 by Hellmark »
Offline csmith1991
Re: Code keyboard.
« Reply #13 on: Tue, 03 September 2013, 16:51:12 »
Win+L doesn't work for you?
Offline Hellmark
Re: Code keyboard.
« Reply #14 on: Tue, 03 September 2013, 17:47:47 »
I don't use Windows. Plus it is satisfying just pounding at the keyboard with my fist and having it do something I wanted it to.
Offline sth
Re: Code keyboard.
« Reply #15 on: Tue, 03 September 2013, 18:19:34 »
edit:
whoops misread ignore pls kthx
Offline gargintua
Re: Code keyboard.
« Reply #16 on: Sun, 08 September 2013, 07:05:19 »
some keycool boards are 'apparently' 21kro? lol
Offline terran5992
  • One With The Cup Rubber
Re: Code keyboard.
« Reply #17 on: Sun, 08 September 2013, 08:07:16 »
i feel that 6 key rollover is fine.
Its not im going to use my face to type
Offline Moosecraft
  • HHKB Pro
Re: Code keyboard.
« Reply #18 on: Sun, 08 September 2013, 08:23:59 »
Duckky boards have NKRO over USB.
Offline C5Allroad
Re: Code keyboard.
« Reply #19 on: Sun, 08 September 2013, 11:55:13 »
Yes they do  :D
Which is why I'm going to buy one now that code keyboards are out of stock.  :'(
Offline laffindude
Re: Code keyboard.
« Reply #20 on: Sun, 08 September 2013, 22:52:40 »
Keep in mind 6KRO is 6keys + all 9 modifiers.
Offline C5Allroad
Re: Code keyboard.
« Reply #21 on: Mon, 09 September 2013, 06:17:27 »
Oh I thought it was 6 keys+ 1 modifier.
Hmm
