Author Topic: QWER set for Poker II  (Read 3296 times)
Offline SquawkVFR
« on: Sun, 01 September 2013, 21:59:51 »
Can someone recommend me a replacement QWER set that will look good / match up with a stock grey Poker II?  I would prefer to stick with stock caps for the rest of the KB unless there is a decent full replacement set that isn't expensive.
Offline terran5992
  • One With The Cup Rubber
Re: QWER set for Poker II
« Reply #1 on: Mon, 02 September 2013, 04:23:50 »
The poker 2 has some unstandard keys. Its gonna be hard to get a full set
Offline SquawkVFR
« Reply #2 on: Mon, 02 September 2013, 04:27:34 »
I should have better stated my question, I am just looking for the "QWER" keys... just hoping to find them in a style that matches the Poker's.
Offline Tym
« Reply #3 on: Mon, 02 September 2013, 04:39:09 »
Im not exactly sure what they are, take a picture and i maybe able to help you better.
Offline SquawkVFR
« Reply #4 on: Mon, 02 September 2013, 04:48:51 »
Here is a stock photo of the key layout / typeface :
Offline Tym
« Reply #5 on: Mon, 02 September 2013, 04:50:57 »
I think you may struggle because people wont want to break up their sets to sell them seperatly im afraid. When you get 60 posts you can post a WTB in the classifieds for them.
Offline AGmurdercore
« Reply #6 on: Mon, 02 September 2013, 07:36:35 »
I am pretty damn sure that you are not understanding what SquawkVFR is asking for. He is looking for just 4 keys - Q+W+E+R to replace on his poker 2. Your best bet might be wasdkeyboards custom caps i think. Or as i think about it the moba set from qwerkeys.
Sadly i can't give you links atm but you should be able to enter the websites just by adding.com on what i said above, or google it. Good luck!
What the hell am I even doing
Offline vun
  • Just one more thing
« Reply #7 on: Mon, 02 September 2013, 07:46:28 »
wasdkeyboards is probably your best bet if you want them to match the stock poker caps, the ones from qwerkeys won't really match.
Finding just those caps in the classifieds is going to be hard since I don't think anyone wants to break up their sets, since they can't do much when they're left with a set missing qwer.
« Reply #8 on: Mon, 02 September 2013, 09:07:28 »
You might want to check this thread too btw: http://geekhack.org/index.php?topic=46495.0 as you can find just some random keys here but i am not sure if the profile of these will fit well with your other caps :S
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #9 on: Mon, 02 September 2013, 09:33:01 »
Right, they are just OEM profile keycap. So I think best would be to get some on whatever color you like from WASD and if you really want them to match visually have them do some centered legends in bank gothic font.
