Author Topic: ErgoDox PCB now also live  (Read 6471 times)
Offline ShakeR
  • * Moderator
    • http://mechanicalkeyboards.com
MechanicalKeyboards.com - What do you type on?
Re: ErgoDox PCB now also live
« Reply #1 on: Mon, 02 September 2013, 04:36:52 »
Whoa, those images are of a version that support PCB-mounted stabilisers!  :thumb:
Unfortunately, the outermost columns don't support 1u keys as is, because of solder-hole placement bug in PCB design.
BTW. Manufactured by pcbwing? ... That text is still on.
« Last Edit: Mon, 02 September 2013, 04:39:32 by Findecanor »
Offline ShakeR
  • * Moderator
« Reply #2 on: Tue, 03 September 2013, 08:44:41 »
Haha, not accurate.  I figured the manufacturer would have known to remove that...  We'll be sure to remove that for next time.  My 'gerber' skills are non-existent so I relied on the manufacturer for text placement / removal / etc.
Offline hoggy
  • * Ergonomics Moderator
« Reply #3 on: Tue, 03 September 2013, 14:30:11 »
Fantastic addition to the line up. Might grab a set at some point.
Any plans to offer a kit including cases and plates?
Offline ShakeR
  • * Moderator
« Reply #4 on: Wed, 04 September 2013, 11:33:29 »
Working on it :)
Offline hoggy
« Reply #5 on: Wed, 04 September 2013, 16:10:01 »
 :D
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #6 on: Wed, 04 September 2013, 16:22:07 »
be cool if you could figure out a case solution to the ergodox other than the litster design, though if you do go the acrylic route please don't do clear top and bottom!
Also I just realized that MechanicalKeyboards is selling the ergodox pcb, the one that supports pcb cherry stabs, for cheaper than MassDrop right now so i think that is pretty cool. I am impressed by the prices of the ergodox and phantom pcbs because with free shipping the price isn't bad at all considering you ship almost always <24 hours as opposed to waiting 2-6 months for a PCB.
