Author Topic: ErgoDox PCB on mechanicalkeyboards.com  (Read 5442 times)
Offline jonathanyu
« on: Mon, 02 September 2013, 01:12:45 »
« Last Edit: Mon, 02 September 2013, 01:14:26 by jonathanyu »
Offline audukent
Re: ErgoDox PCB on http://mechanicalkeyboards.com
« Reply #1 on: Mon, 02 September 2013, 01:13:30 »
Nice find
[LZ-GH - 62g mx greens and 62g mx clears]    [Ducky Shine - mx browns]    [RACE mxMini - mxreds]  [POKER II - mx Blacks]    [KPAD - 62g mx blacks]
Offline daerid
    • Rossipedia
Re: ErgoDox PCB on mechanicalkeyboards.com
« Reply #2 on: Mon, 02 September 2013, 01:29:02 »
Damn... white PCBs? Now I wish I'd waited before putting together my second one.
Offline jonathanyu
« Reply #3 on: Mon, 02 September 2013, 01:38:17 »
the white pcb look pretty good  :D
so i just bought 2 phantom pcb yesterday, and bought 2 ergodox pcb today  :blank: i don' even know what i am going to do with them
Offline daerid
    • Rossipedia
« Reply #4 on: Mon, 02 September 2013, 10:20:31 »
I might actually put together a 3rd ErgoDox with black acrylic center plates and the white PCB, and white PBT caps... would be seeexxxxyyyy
Offline SeriouSSpotS
  • 60% is love, 60% is life
« Reply #5 on: Mon, 02 September 2013, 10:26:10 »
I like the pcb, looks awesome
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #6 on: Tue, 03 September 2013, 00:48:34 »
love the shout out to SmallFry on there
dont need anymore ergodox unless a new case design comes up
« Reply #8 on: Tue, 03 September 2013, 01:47:42 »
If I didn't need a new laptop, I'd be all over this.  It would be perfect for figuring out a wood case for ergodox as well.
Offline j2c8w6f8
« Reply #9 on: Tue, 03 September 2013, 05:12:18 »
Nice!
Offline dragonxx21
« Reply #10 on: Thu, 05 September 2013, 00:00:31 »
I noticed that the ErgoDox PCB on mechanicalkeyboards.com is $38 for the set of 2, but there is a massdrop going on right now for $22 for one piece. Is there any difference between the pcb that mechanicalkeyboards is selling, and the one in the massdrop, that would make the price differ so much? The only difference I see is in the colour, and the mechanicalkeyboards one looks better imo.
Keyboards Owned:
Realforce Topre 91 Key JIS Profile - Main
CM Quickfire Rapid Blue Switches
IBM Model M in Industrial Shell
Offline Glod
    • YouTube Channel
« Reply #11 on: Thu, 05 September 2013, 00:48:39 »
the mechanical keyboards version also has free shipping so its 38$ total for US
the mechanical keyboards version is in stock now and ships same day
the mechanical keyboards version is a revision that allows pcb mounted stabilizers. The change doesn't matter if you are using a layered acrylic case but if at some time a case was created that was either plate-less or allowed pcb stabilizers it would be sweet.
virdict: the mechanical keyboards version looks to be the better option, it just doesnt come with any other parts  like diodes and teensy just as the massdrop bare pcb also does not come with anything
Offline dragonxx21
« Reply #12 on: Thu, 05 September 2013, 00:52:04 »
Thank you, this was just the answer I was looking for. Currently trying to see how much it would cost to make the ErgoDox right now, and knowing that the mechanical keyboards version looks to be the better option, is a big help.
Keyboards Owned:
Offline Glod
    • YouTube Channel
« Reply #13 on: Thu, 05 September 2013, 01:03:57 »
i mean the case is the biggest problem right now with buying the bare pcbs from either Mechanical Keyboards or MassDrop
Acquiring the diodes, teensy, expander, etc is pretty easy and switches are currently well stocked at different places. But a case is just not for sale anywhere, only options right now this moment is either having acrylic layers cut using the litster files, or have a 3d printed case made via Shapeways or somewhere else which would require dropping more than $300 for the case alone.
Offline dragonxx21
« Reply #14 on: Thu, 05 September 2013, 01:05:26 »
Acquiring the diodes, teensy, expander, etc is pretty easy and switches are currently well stocked at different places. But a case is just not for sale anywhere, only options right now this moment is either having acrylic layers cut using the litster files, or have a 3d printed case made via Shapeways or somewhere else.
Have any idea how much it would cost to get the cases cut or printed?
Keyboards Owned:
Offline Glod
    • YouTube Channel
« Reply #15 on: Thu, 05 September 2013, 01:11:23 »
i dont have laser cutting sources but if you find someone that does acrylic the dxf files to send to them is here
http://www.ergodox.org/Downloads.aspx, the middle layers have to be a specific thickness but the top and bottom layers can be any thickness.
This requires shopping around for sheets of acrylic and someone to cut them but it is the cheapest option.
the shapeways case is for sale here
http://www.shapeways.com/search?q=ergodox
the total cost of it would start at over $200 with the cheapest materials selected
the cad files for the 3d printed case is also located at http://www.ergodox.org/Downloads.aspx
Offline dragonxx21
« Reply #16 on: Thu, 05 September 2013, 01:29:20 »
Yeah, the build looks to be around $250 right now. If I can find someone who could lazer cut for a cheap price, I may go with that route, otherwise maybe waiting for the next group buy could be a better idea.
Keyboards Owned:
Offline BliTzKiN
« Reply #17 on: Thu, 05 September 2013, 11:21:00 »
Those PCBs are really pretty, I have an ergodox from the previous drop coming in soon and considering weather I should buy these just because they look so goodz :(
Offline vatin
« Reply #18 on: Thu, 05 September 2013, 11:44:25 »
Great. Now people could get spare pcbs or build their edox without having to depend on groupbuy.
HHKB Professional Classic
Offline thadood
« Reply #19 on: Thu, 05 September 2013, 15:22:44 »
This is pretty awesome, I love the color. I'm in agreeance with most of you - the case is the most difficult/expensive part.
Offline AcidFire
    • Axios - The Open Source Modular Ergonomic Keyboard
« Reply #20 on: Thu, 05 September 2013, 15:55:53 »
I'll be shipping a case off to Daerid pretty quick to test the fit of the materials I have on hand. If everything ends up working out a Black (or other colors) + Clear (or other colors) are going to land somewhere around the 60-80 mark without hardware. The big question right now is in the materials, what I have should total up to the same thickness, but in a different stack so I need to make sure everything fits right.
Offline dragonxx21
« Reply #21 on: Thu, 05 September 2013, 16:52:17 »
Would that be 60-80 each or as a pair?
Keyboards Owned:
Offline AcidFire
« Reply #22 on: Thu, 05 September 2013, 17:01:45 »
That would be for a pair.
Offline dragonxx21
« Reply #23 on: Thu, 05 September 2013, 17:12:34 »
Well if you ever do get to selling them, I'd be very interested.
Keyboards Owned:
« Reply #24 on: Thu, 05 September 2013, 20:06:44 »
I only want one, Does anyone want to go splits? I also have an extra massdrop PCB, so if you're okay with two colours, you could save!
I thought it was $38 shipped for one. silly me!
Offline Tarzan
  • formerly known as Greystoke
« Reply #25 on: Fri, 06 September 2013, 08:44:33 »
I need an ErgoDox case, and your estimated price is perfect.   ;D
« Reply #26 on: Fri, 06 September 2013, 11:42:39 »
Bah. Building your own ErgoDox case out of wood or sheet styrene wouldn't be that difficult if you are a bit crafty. The PCB supports PCB-mounting, so no laser-cutting or CNC is necessary.
