Author Topic: Ducky Shine 3 Reactive Mode  (Read 3886 times)
Offline dman777
« on: Mon, 02 September 2013, 10:35:48 »
In Reactive mode on my Ducky Shine 3(Orange LED) I am not able to get the cool strobe effect that this guy is getting:
Is it because I have orange LED's and not blue LED's? Or is there a a special way to make it?
Here is mine:
Offline ping111
Re: Ducky Shine 3 Reactive Mode
« Reply #1 on: Mon, 02 September 2013, 10:48:56 »
That's just the quality of his camera.  Sorry dude - the camera is probably shooting 30 fps, and LED's flash 60 times a second or more.  If you're really desperate, get a crappy webcam, strap it to your head, and put a monitor in front of your KB.
In My Possession:
Max Keyboard Nighthawk X8 Mechanical Keyboard - Cherry MX Brown - Blue LED Backlighting
Wanted:
KBTalking PURE - Tenkeyless - Cherry MX Brown - Green LED Backlighting
Offline ReTiCuLe
« Reply #2 on: Mon, 02 September 2013, 10:53:19 »
Dman,
Do you think the Shine 3 is a worthy upgrade over a DAS KB ? The lighting is cool, I was considering the same color as yours. Does it have switchable polling rates? The manufacturer website is down, I tried looking more in dept.
Thanks,
ReT
Offline HendyZone
  • HHKB Elite
    • MechanicalKeyboards.co.id
« Reply #3 on: Mon, 02 September 2013, 11:16:59 »
Dman,
Thanks,
ReT
if you are looking for the backlit it's worthed  :thumb:
Offline SeriouSSpotS
  • 60% is love, 60% is life
« Reply #4 on: Mon, 02 September 2013, 11:18:32 »
Offline falkentyne
« Reply #5 on: Mon, 02 September 2013, 14:31:02 »
That has to do with his camera.  Reactive mode Backlights don't strobe like that :)
You can notice similar things when recording images on something like a lightboost 3d monitor, too, if you don't have high enough response/frame rate on the cam.
