Author Topic: Weller WLC100?  (Read 5198 times)
Offline zoolzoo
Weller WLC100?
« on: Mon, 02 September 2013, 13:06:36 »
What do you guys think of this for getting into modding?
http://www.amazon.com/Weller-WLC100-40-Watt-Soldering-Station/dp/B000AS28UC
Seems like you cant really go wrong here for $40 but I dont know much about soldering, though Ive done it a bit before.
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Offline pixel5
    • pixel5
Re: Weller WLC100?
« Reply #1 on: Mon, 02 September 2013, 13:08:53 »
I've been looking at this. I'm just kinda getting into it as well. I modded my Poker 2 with a cheap radioshack pencil, but it kinda seemed harder than it needed to be. The tip was too large and I found that you really need a holder for an iron.
I just don't like the chisel tip that comes with that Weller. Is there a small conical tip I can get for cheap with it?
Poker II
Quickfire Rapid
BUY MY CRAP
Offline zoolzoo
Re: Weller WLC100?
« Reply #2 on: Mon, 02 September 2013, 13:10:17 »
On the side of the box it shows a picture of a bunch of different tips. I wonder if they come with the kit?
Offline pixel5
    • pixel5
Re: Weller WLC100?
« Reply #3 on: Mon, 02 September 2013, 13:10:50 »
The description only lists one. I think that picture is just advertising all the tips they sell.
Poker II
Quickfire Rapid
BUY MY CRAP
Offline keymaster
  • Topre Revolution Theorist
Re: Weller WLC100?
« Reply #4 on: Mon, 02 September 2013, 13:11:20 »
I have one. It works great if all you'll be doing is modding a few keyboards. You may want to get a smaller tip, though. It really solders/desolders much cleaner with a smaller tip.
Offline zoolzoo
Re: Weller WLC100?
« Reply #5 on: Mon, 02 September 2013, 13:12:23 »
Thanks. Where can you get a pointy tip that is 100% compatible?
[edit] for example will this just fit right on it?
http://www.amazon.com/Weller-ST7-X0-79-Series-Conical/dp/B000B607OC/ref=pd_sim_hi_1
Offline pixel5
    • pixel5
Re: Weller WLC100?
« Reply #6 on: Mon, 02 September 2013, 13:13:43 »
Poker II
Quickfire Rapid
BUY MY CRAP
Offline elton5354
Re: Weller WLC100?
« Reply #7 on: Mon, 02 September 2013, 13:14:40 »
The same site. Lol.
You want the ST6 or ST7.  I think if you search the website, you may find it.
Offline Turkishrambo
Re: Weller WLC100?
« Reply #8 on: Mon, 02 September 2013, 13:15:36 »
Its a great starting iron :)
Offline zoolzoo
Re: Weller WLC100?
« Reply #9 on: Mon, 02 September 2013, 13:19:31 »
The same site. Lol.
Perfect thanks!
Offline keymaster
Re: Weller WLC100?
« Reply #10 on: Mon, 02 September 2013, 13:25:03 »
Yes, that will fit. Its the same one I purchased.
