Author Topic: ALPS: Servicing, but can't open switches  (Read 2090 times)
Offline ihasmario
« on: Tue, 03 September 2013, 08:17:54 »
Hello, I want to replace the springs and possibly leafs in an ALPS keyboard, but I cant open the switch. Screwdrivers just slide off.... Pls respond
Offline Tarzan
  • formerly known as Greystoke
Re: ALPS: Servicing, but can't open switches
« Reply #1 on: Tue, 03 September 2013, 08:20:28 »
Are those actually Alps switches?  I was expecting to see something with stems more like these:
« Last Edit: Tue, 03 September 2013, 08:30:43 by Greystoke »
Offline ihasmario
« Reply #2 on: Tue, 03 September 2013, 08:21:56 »
They are ALPS plate spring switches on IBM 5576s
Offline Tarzan
« Reply #3 on: Tue, 03 September 2013, 08:29:58 »
Probably explains why I've never seen examples of these in real life, that's a pretty rare keyboard!   :-[
It may be that instructions for opening Alps switches are geared towards Alps CM, I'll have to defer to someone more experienced for a substantive answer.
Offline ihasmario
« Reply #4 on: Tue, 03 September 2013, 08:32:58 »
The switch casing itself seems fairly similar, but I just cant get it open with two screw drivers, as they slide off.
Some more info for onlookers: they are plate mounted, I am trying to replace some of the springs, and hope to increase the actuation force (because pianist fingers)
« Reply #5 on: Tue, 03 September 2013, 08:58:20 »
Offline ihasmario
« Reply #6 on: Tue, 03 September 2013, 09:25:15 »
Great, thanks. Will try later.
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #7 on: Tue, 03 September 2013, 19:42:00 »
Alps Electric made a lot of different switches; the SKCL/SKCM/SK??/???? types ("Alps CM", or just "Alps") are by far the most common. The next most common may be their corned beef tin linears (some Atari 800XL, some old Toshiba laptops etc). Those Alps plate spring switches are not one of the common ones.
Their switches include metal contact, conductive dome inside discrete switches, spring over membrane, and plain old rubber domes.
Most of the ones I know of are listed here: http://deskthority.net/wiki/Category:Alps_switches
My favourite is probably this one that Sandy just discovered recently:
http://deskthority.net/wiki/Alps_ultra_low_profile
Bore Awards
