Author Topic: LED Modding my Vortex KBT Oni TKL 87  (Read 1842 times)
Offline blizzardcraft
« on: Tue, 03 September 2013, 10:15:28 »
Hi guys, was wondering about the circuitry of vortex.,.. anybody mod-ed their ONI KBT with LED?
would like to see a picture of it , how it turned out :)
does multi-colour works? ( eg : F1~F9 yellow, alphabets white )
I'm afraid about i'm not able to achieve equal brightness if I'm going for multi-colour LED modding.
Offline laffindude
Re: LED Modding my Vortex KBT Oni TKL 87
« Reply #1 on: Tue, 03 September 2013, 21:15:55 »
The LED-less version cannot be modded. It is missing the LED controller.
Offline terran5992
  • One With The Cup Rubber
« Reply #2 on: Tue, 03 September 2013, 21:57:16 »
Does the pcb have the led holes?
Offline gnubag
« Reply #3 on: Tue, 03 September 2013, 22:09:13 »
« Reply #4 on: Wed, 04 September 2013, 05:13:43 »
there's LED hole there... whats LED controller? to control the brightness?
what if Im willing to settle down with a constant brightness?
 forgive me, i'm new to MKBs , just joined the community :)
Offline elttaboi
« Reply #5 on: Wed, 04 September 2013, 17:52:24 »
Maybe if you figure out the circuit, you could possibly just give the leds power, but they'd always be on.
Offline laffindude
« Reply #6 on: Thu, 05 September 2013, 04:30:25 »
LED controller is just an IC that controls the LEDs. Unlikely you'll be able to get enough brightness if you wired it up and constant current to power the LEDs. You will be limited to 500mA @ 5v from USB.
Offline yasuo
  • spanengan puyeng newbie
« Reply #7 on: Thu, 05 September 2013, 04:32:54 »
handwired with resistor,cable,etc
Logitech MK220 Colemak DH
« Reply #8 on: Fri, 06 September 2013, 00:40:51 »
will that voltage limit results in a bad lighting appearance? o_o
would like to see a mod-ed ONI KBT.. any knowledge about anyone already mod-ed theirs? :)
