Author Topic: What kinds of DIY boards are available?  (Read 6548 times)
Offline dragonxx21
« on: Tue, 03 September 2013, 15:21:53 »
While i may not be considering a DIY board for a while, I'm still interested in finding out what kinds of boards are available in the market right now. Note: I'm talking about boards similar to the ErgoDox that comes with most of the required parts and just require assembly.
Keyboards Owned:
Realforce Topre 91 Key JIS Profile - Main
CM Quickfire Rapid Blue Switches
IBM Model M in Industrial Shell
Offline pixel5
    • pixel5
Re: What kinds of DIY boards are available?
« Reply #1 on: Tue, 03 September 2013, 15:25:09 »
I'm about to start a handwired 60% project. It will be using a teensy 2.0. If you have a plate, switches, and a microcontroller you can make a keyboard!
Other than that, the Phantom, GH60, GH75.
Poker II
Quickfire Rapid
BUY MY CRAP
Offline damorgue
    • Personal portfolio
« Reply #2 on: Tue, 03 September 2013, 15:28:15 »
Availability is a bit so so with several of the ones mentioned, as well as these, but there are several korean keybaords, the GH Pad, the "Light", The ErgoGP amongst others.
Offline dragonxx21
« Reply #3 on: Tue, 03 September 2013, 17:21:14 »
So if you were to build a board from scratch (assuming you are using stock PCBs and not making one), what would you need? From pixel's post, I would need switches, a microcontroller (which I'm assuming is the teensy in his case?), and a plate to mount the switches onto. Would you need to design and produce your own case, or would you be able to purchase on premade? I'm sorry if it seems like I have no idea what I'm talking about, as I really don't.
Keyboards Owned:
Offline pixel5
    • pixel5
« Reply #4 on: Tue, 03 September 2013, 17:29:02 »
Things needed to make a keyboard:
PCB Route:
1. Switches
2. PCB
3. Plate (optional if your PCB supports PCB mounted switches)
4. Microcontroller (can be built into the PCB in some cases)
5. Case
6. Caps
Handwire route:
1. Switches
2. Plate
3. Diodes
4. Wiring (insulated and non-insulated)
5. Microcontroller (such as the teensy)
6. Case
7. Caps
Tools needed:
1. Soldering iron/station/gun
2. Solder
3. Screwdriver
4. Wire cutters
5. Any design-specific tools you need
Poker II
Quickfire Rapid
BUY MY CRAP
Offline dragonxx21
« Reply #5 on: Tue, 03 September 2013, 17:44:11 »
PCB Route:
1. Switches
2. PCB
5. Case
6. Caps
Handwire route:
1. Switches
2. Plate
3. Diodes
6. Case
7. Caps
Tools needed:
2. Solder
3. Screwdriver
4. Wire cutters
What kind of notable differences are there between the handwired and pcb route?
Keyboards Owned:
Offline pixel5
    • pixel5
« Reply #6 on: Tue, 03 September 2013, 17:52:44 »
PCB Route:
1. Switches
2. PCB
5. Case
6. Caps
Handwire route:
1. Switches
2. Plate
3. Diodes
6. Case
7. Caps
Tools needed:
2. Solder
3. Screwdriver
4. Wire cutters
From a usability perspective, I don't think so. But I'm about to find out!
Poker II
Quickfire Rapid
BUY MY CRAP
Offline dragonxx21
« Reply #7 on: Tue, 03 September 2013, 17:56:35 »
Well aside from usage wise, I meant how do they differ from each other? Are the switches connected differently in the handwire method?
Keyboards Owned:
Offline pixel5
    • pixel5
« Reply #8 on: Tue, 03 September 2013, 17:58:54 »
Do a search for Brownfox keyboard. Someone on deskthority did one very nicely.
Poker II
Quickfire Rapid
BUY MY CRAP
Offline dragonxx21
« Reply #9 on: Tue, 03 September 2013, 18:14:27 »
From what I got, handwired switches are connected together through the diodes, and must be soldered together, and the switches are required to be plate mounted, whereas with the PCB, you solder the switches directly to the board. Is this a correct assumption?
Edit: I also noticed that all the components for PCB boards connect directly to the PCB, and in handwired boards, the switches are individually wired to the controller.
« Last Edit: Tue, 03 September 2013, 18:17:12 by dragonxx21 »
Keyboards Owned:
Offline pixel5
    • pixel5
« Reply #10 on: Tue, 03 September 2013, 18:19:42 »
That's basically right. There are a few PCBs that require a controller to be added, like the ergo dox and phantom (both use the Teensy 2.0)
Poker II
Quickfire Rapid
BUY MY CRAP
Offline dragonxx21
« Reply #11 on: Tue, 03 September 2013, 18:27:07 »
So there aren't any advantages to doing PCB over handwiring, or vise versa, at least none that you know of?
Keyboards Owned:
Offline pixel5
    • pixel5
« Reply #12 on: Tue, 03 September 2013, 18:58:17 »
PCB is definitely going to be a cleaner way of doing things. The wiring can get out of control if you let it.
Poker II
Quickfire Rapid
BUY MY CRAP
Offline Hellmark
« Reply #13 on: Tue, 03 September 2013, 20:35:13 »
Handwiring is cheaper for one offs. Phantom PCB costs $40 plus shipping, whereas handwiring is just a buck of wire and your time. Even bigger difference for custom PCBs.
Offline pixel5
    • pixel5
« Reply #14 on: Tue, 03 September 2013, 20:44:27 »
+$15 for a microcontroller like teensy. :D
Poker II
Quickfire Rapid
BUY MY CRAP
Offline dragonxx21
« Reply #15 on: Tue, 03 September 2013, 23:34:41 »
Quality wise, would a PCB shine over handwiring, or will they be similar if both are correctly done? And does handwiring depend on the type of build you are doing or will the method outlined here work with most builds?
Keyboards Owned:
Offline yasuo
  • spanengan puyeng newbie
« Reply #16 on: Tue, 03 September 2013, 23:42:04 »
For handwired The main is plate
For PCB is PCB,you must making design PCB(you want) with KiCad
Logitech MK220 Colemak DH
Offline dragonxx21
« Reply #17 on: Tue, 03 September 2013, 23:46:28 »
Yes I realize this, but I was wondering if there were different methods for wiring the switches together.
Keyboards Owned:
