Author Topic: Wondering about white pbt keycap!  (Read 3224 times)
Offline sor
« on: Tue, 03 September 2013, 15:32:58 »
Ever since i had my White Keycool PBT some picture here : http://geekhack.org/index.php?topic=47989.0
how do u take good care of white PBT keycaps other then wash or wiping ur hands before use??and how to clean it to maintain its whiteness ;D
also whats the best combinations of keycaps on a white tkl board!
Thanks guys :thumb:
ESPORTS!
Offline lcs
  • Lover of Grape Drank
  • はやく
Re: Wondering about white pbt keycap!
« Reply #1 on: Tue, 03 September 2013, 15:34:56 »
Thanks guys :thumb:
You can use denture tabs to clean caps. It works really well.
As for the best combinations, it is totally up to taste :)
Offline eth0s
  • Peace & Love
« Reply #2 on: Tue, 03 September 2013, 15:40:08 »
Thanks guys :thumb:
lol.  Unless you work on your car before typing on your keyboard, it's not really that big of a problem.   Also not eating curry mei fun at the keyboard is another good idea.
But white PBT will not get any dirtier than other keycaps.  You can wipe them down with a damp cloth if they get really sticky, messy.  The white PBT doesn't stain under normal use.
Offline sor
« Reply #3 on: Tue, 03 September 2013, 16:16:40 »
Thanks guys :thumb:
denture tabs ah,noted. Thanks!
Thanks guys :thumb:
i need some ideas! i bought the vortex pbt black-on-black dyesub none i found interesting on a white body seems like the keycool with rgb mods and red esc  alone is nice
anyway Thanks!
ESPORTS!
