Author Topic: Is the Realforce 87u Portable?  (Read 1723 times)
Offline mrelectric
« on: Tue, 03 September 2013, 16:38:53 »
Hey guys, I'm looking to buy a new topre board and was just wondering whether the 87u would be considered portable? I won't be walking all day, but maybe for 2~ hours overall and need something I can carry in my messenger bag with a laptop. My current choices are the Realforce, HHKB2 and FC660C, but i've crossed of FC660C because I live in England and for the price of getting one of those I can easily proxy over a realforce/HHKB2 Silent versions for a bit less.
I kind of need the arrow keys and I've become pretty accustomed to the standard layout, so I was just wondering whether the Realforce 87U would be considered portable? If not then can we discuss the learning curve for the HHKB2?
Thanks!!!!
Offline esoomenona
  • Gnillort?
Re: Is the Realforce 87u Portable?
« Reply #1 on: Tue, 03 September 2013, 16:45:39 »
What do you "kind of" need arrow keys for? The weight difference between a Realforce and a HHKB is significant. That being said, people tote TKL boards around all the time.
Offline mrelectric
« Reply #2 on: Tue, 03 September 2013, 16:47:31 »
Browsing the internet haha :P, I suppose I can attempt to get used to the HHKB2 profile, then again i'm thinking of getting a tablet pc so maybe scrolling won't be that bad.
Offline daerid
    • Rossipedia
« Reply #3 on: Tue, 03 September 2013, 18:04:47 »
Depends on what you consider portable. They're not that much smaller than a standard board. If portability and arrow keys are that important, I'd spend the extra and import an FC660C. It'll be well worth it.
Offline spiceBar
    • ChessTiger.com
« Reply #4 on: Wed, 04 September 2013, 12:35:06 »
Agreed. The difference in weight and size in significant. In the long run, you are going to forget about the price, but not about the everyday inconvenience.
Offline mauri
« Reply #5 on: Wed, 04 September 2013, 12:37:15 »
Comparing tkl to 60% or 65% seems a bit redundant, I don't think I'd be carrying my tkl around, perhaps 60% but definitely not anything bigger.
I AM BABAR KING OF THE ELEPHANTS
Offline jameslr
« Reply #6 on: Wed, 04 September 2013, 12:45:23 »
A RF87U isn't meant to be considered compact. I think if you're looking for a compact board - the HHKB Pro 2 or the FC660C are your best bet in the Topre variety. My RF87U is also considerably bigger than my other TKL board (Filco MJ2 TKL).
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline CommunistWitchDr
  • >implying keyboards
« Reply #7 on: Wed, 04 September 2013, 12:50:38 »
I find tenkeyless to be pretty portable. I still usually carried around my poker (it had blacks) since my tkl has greens and when I'm using something portable it has to be quiet.
Ever since I got my edox I just use that and it's plenty portable.
Offline daerid
    • Rossipedia
« Reply #8 on: Wed, 04 September 2013, 12:52:23 »
The classic case is surprisingly portable. I wouldn't really want to travel around with the full hand case though
