Author Topic: Cherry MX White Switches  (Read 6581 times)
Offline divito
« on: Tue, 03 September 2013, 17:57:14 »
Not sure how many people have seen this, for the so-called elusive white switches, but was perusing eBay like many of you probably do and saw this:
http://www.ebay.ca/itm/111094898458?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
On my watch list, it lists quantity available as 196. Thought I'd let people know in case someone is interested in them.
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
Re: Cherry MX White Switches
« Reply #1 on: Tue, 03 September 2013, 17:59:48 »
That's a clear switch and $3.50 a switch? ? ? You can get clears for $.60-$.80. I think Mouser's price is like $.86.
Offline esoomenona
  • Gnillort?
« Reply #2 on: Tue, 03 September 2013, 18:00:02 »
This is a horrible price... And that picture is a Clear.
Offline divito
« Reply #3 on: Tue, 03 September 2013, 18:02:28 »
Hmm, so perhaps a misinformed seller, or intentional subterfuge? I didn't pay much mind to the photo, though I don't think I've ever seen a white/clear comparison photo. At $3.50 a switch, I was surmising it based on the white switch and its non-common nature.
Edit - And given the information, if a mod wants to delete the thread, that's fine.
« Last Edit: Tue, 03 September 2013, 18:05:50 by divito »
Offline ComradeSniper
  • HHKB Pro
« Reply #4 on: Tue, 03 September 2013, 18:05:48 »
Give me 5 minutes
« Reply #5 on: Tue, 03 September 2013, 18:06:58 »
Even *if* it was a White, it wouldn't warrant a $3.50 price. I bought mine for about $.72/switch.
From the DT Wiki (Clear and White Articles):
White
Clear
They're literally white and clear/opaque.
Offline divito
« Reply #6 on: Tue, 03 September 2013, 18:08:22 »
Hmmmmmmm, after some searching, seems I'm still confused.
From: http://deskthority.net/photos-videos-f8/white-vs-clear-vs-clicky-clear-2-0-t2017.html
Seems it's far more likely to be a current clear rather than an old-style clear/white as listed on the DT thread. I apologize for my green-ness.
« Last Edit: Tue, 03 September 2013, 18:11:48 by divito »
Offline esoomenona
  • Gnillort?
« Reply #7 on: Tue, 03 September 2013, 18:09:04 »
As far as "rarity" of switches go, I don't think it affects price all too much. Perhaps $0.10-0.20, but not dollars. Thus, even if Whites aren't all too prevalent, and are truly desired, they would likely never go for that much a switch.
Also, you can tell the difference between the Clear and White by the fact that the Clear is a bit translucent, whereas the White is very bright white.
Offline TheFlyingRaccoon
  • HHKB Pro
  • Cable maker and future engineer
« Reply #8 on: Tue, 03 September 2013, 18:13:00 »
Left is clear, right is white. See?
HHKB Pro 2   SmallFry Keyboard
  • HHKB Pro
« Reply #9 on: Tue, 03 September 2013, 18:17:26 »
You've probably got the point by now, but for the sake of further clarity, here is a clear between two whites:
Offline esoomenona
  • Gnillort?
« Reply #10 on: Tue, 03 September 2013, 18:19:19 »
Did I mention that one of these is Clear and the other might be White?
Offline esoomenona
  • Gnillort?
« Reply #11 on: Tue, 03 September 2013, 18:20:12 »
Or is this one the White?
Offline esoomenona
  • Gnillort?
« Reply #12 on: Tue, 03 September 2013, 18:20:48 »
And here's a Vintage Clear:
Offline esoomenona
  • Gnillort?
« Reply #13 on: Tue, 03 September 2013, 18:21:28 »
And don't forget these old Whites:
Offline divito
« Reply #14 on: Tue, 03 September 2013, 18:24:00 »
Yes, but can do without the condescension over my apparent daftness. Still no comment on the DT picture I posted though.
Offline esoomenona
  • Gnillort?
« Reply #15 on: Tue, 03 September 2013, 18:25:56 »
Back in the olden years, they called those "White". They say clicky there, but there were also "White" linear switches. As it stands, the convention these days is the Clear is semi-translucent, whereas the White is the solid white. There is a possibility that they could be old switches, but it's unlikely.
Offline jonathanyu
« Reply #16 on: Wed, 04 September 2013, 00:07:56 »
after this picture, i am more confuse
Offline Larken
« Reply #17 on: Wed, 04 September 2013, 00:24:12 »
From the deskthority wiki:
Vintage Type A: 80 cN, translucent white stem, black click-slider — 1987–?
Vintage Type B: 50 cN, translucent white stem, translucent white click-slider — 1989–?
Modern: 80 cN, white stem, black-slider — 2007–2012+?
The Type B has been reported to feel identical to modern Cherry MX Blue. Because of the harder types' similarity to Cherry MX Green, it has sometimes been nicknamed "albino green".
The sliders in the newer switches are proper white, while the older ones are translucent. The slider construction is a bit different. The spring is identical to the one in the vintage Type-A clicky switch and feels identical.
The switch is not to be confused with the Cherry MX Clear which also has translucent white sliders. Modern switches can be told apart more easily because their sliders are opaque, but vintage switches are visually almost indistinguishable to Clears.
| Ergodox #1 | Ergodox #2 |
Offline BlueBär
« Reply #18 on: Wed, 04 September 2013, 02:38:46 »
Clicky switches should all have a little nub on the top of the slider, the switch on the ebay listing doesn't seem to have one. I'm not sure if they always had that nub though, can somebody who has old clicky switches confirm?
Offline CalmB4tehPwn
  • Demon of the Fall
« Reply #19 on: Wed, 04 September 2013, 02:47:24 »
All of the clears posted in this thread (aside from the vintage White/Clear) has no nub. Curious, that.
"I seek a great warrior" - Luke Skywalker
"Great Warrior, Hmm? War does not make one great." - Master Jedi Yoda
Offline BlueBär
« Reply #20 on: Wed, 04 September 2013, 02:54:57 »
All of the non-clickies posted in this thread has no nub. Curious, that.
FTFY
With clicky I mean white, grey, blue and green, so this should be a good indicator if it is a white/clicky or a clear/non-clicky.
  • Demon of the Fall
« Reply #21 on: Wed, 04 September 2013, 04:10:34 »
Oh! You said clicky, for some reason I read Tactile. Disregard.
Offline esoomenona
  • Gnillort?
« Reply #22 on: Wed, 04 September 2013, 05:32:14 »
I think you're right. You can see it in the picture of the Whites, the Blue, and if you look closely enough of that old White, you can see it as well.
« Reply #23 on: Wed, 04 September 2013, 05:37:05 »
Yeah. Whites, blues and greens all have the nubs. Pretty sure the ebay listing is a regular clear.
  • HHKB Pro
« Reply #24 on: Wed, 04 September 2013, 08:56:33 »
Oh cool, I never noticed that only clicky switches had that.
