Author Topic: New Cherry XS G84 range  (Read 3485 times)
Offline Chloe
  • Switch Kitten
« on: Thu, 27 November 2008, 20:51:29 »
http://www.cherry.de/english/products/compact_keyboards.htm
I quite like the look of the G84-5200, this would be my ideal layout. If only Cherry could make one like this with MX switches!
Offline Eclairz
« Reply #1 on: Fri, 28 November 2008, 03:21:49 »
Really nice find cherry hasn't invented any new layouts(for mechanical keyboards) for a very long time now.
http://www.cherry.de/english/products/compact_keyboards_XS_Complete_Keyboard.htm
This one is almost perfect for my needs, with my only annoyance is the arrangement of the home, end, pgup, pgdn, insert,delete key arrangement. to be honest i dont care too much about pg up and pgdn and I got used to the G84-4100 arrangement of the delete key near the space bar but home and end keys are always difficult to get to and are really necessary for my programming workflow.
Lenovo ThinkPad TrackPoint Keyboard
RealForce 45g UK 88UB
FILCO Majestouch TenKeyPad
Offline Eclairz
« Reply #2 on: Fri, 28 November 2008, 03:33:16 »
http://www.cherry.de/english/products/compact_keyboards_SPOS_G86-61400.htm
I think if cherry would make this keyboard with mx switches, remove one or two rows of the programmable/relegendable keys, and make the keyboard in a european format i would be might interested in it. Looks about the same size as a macally mk96 width wise but due to extra rows of programmable keys looks fatter in a way.
Offline Chloe
  • Switch Kitten
« Reply #3 on: Fri, 28 November 2008, 05:13:56 »
I can't really tell if these XS are lacking the right Control. I miss that when I am on the G84-4100 and have remapped Delete to it. I like the arrangement of Home, PgUp, PgDn and End in a single row.
They don't seem to have the option of no Windows keys on this new range. I find the bottom row on the G84-4100 too cramped with them, the keys are slightly smaller width than the alphabet keys to fit 14 keys. On the XS it looks like they have just added left Win and Appskey to the G84-4400 (10) so it might not be so bad.
Offline Eclairz
« Reply #4 on: Fri, 28 November 2008, 15:15:25 »
To be honest i've never used the right control but then again i've used many compact keyboards which tend to omit the key in question. The only bad thing about ML keys is shorter travel and you have to type more correctly.
If you still hankering for longer travel keys then maybe an alps might suit you instead I own two alps based keyboards
A left hand keyboard which has advantages of shorter travel between mouse and keyboard but still retains the numpad
http://geekhack.org/attachment.php?attachmentid=162&d=1221911672
http://geekhack.org/attachment.php?attachmentid=161&d=1221911665
And a macally spacesaver mk 96 keyboard
http://geekhack.org/attachment.php?attachmentid=163&d=1221911677
But I think if you really like the way the new cherry g84-5200 layout then the best solution is a cherry based DSI
http://cgi.ebay.com/DSI-White-Modular-Mac-Keyboard-Mechanical-Tactile-Keys_W0QQitemZ190269512308QQcmdZViewItemQQimsxZ20081126?IMSfp=TL081126113001r21644
almost the same but with the option of brown/blue? cherry switches and addon numpad/joystick later. Unfortunately not available in london without paying for customs and alot of postage/packing
Offline Chloe
  • Switch Kitten
« Reply #5 on: Fri, 28 November 2008, 19:19:39 »
I don't think I will be able to live with US layout. I might if it had blank keycaps. I'd want it to come with them if I were to spend that much.
I don't mind the ML switches. I can type on them without bottoming out. My G84-4100 still has the plastic friction noise/feel but the compactness makes up for it.
I'm so used to the Compaq MX 11800 now, it would have to be really special for me to switch. I think my ideal keyboard would be a UK layout MX-1800 without Windows keys.
