Author Topic: where can I get 2.2K Ω resistor in small amount?  (Read 4716 times)
Offline jonathanyu
« on: Thu, 05 September 2013, 21:53:51 »
hi, I just bought the ergodox pcb from mechanicalkeyboards.com
it doesn't include diodes, resistor, etc
2.2K Ω resistor can be bought on digikey.com, but the minimum quantity is 5000
so is there any place that i can buy a small amount?
Offline TheFlyingRaccoon
  • HHKB Pro
  • Cable maker and future engineer
Re: where can I get 2.2K Ω resistor in small amount?
« Reply #1 on: Thu, 05 September 2013, 23:22:58 »
Mouser appears to have what you're looking for.
HHKB Pro 2   SmallFry Keyboard
Offline PepperPanda
« Reply #2 on: Thu, 05 September 2013, 23:27:59 »
Depending on how many your getting might be cheaper to buy from Amazon or ebay.
Offline jonathanyu
« Reply #3 on: Thu, 05 September 2013, 23:54:27 »
 :D thanks! i think i will buy it on mouser
  • HHKB Pro
« Reply #4 on: Fri, 06 September 2013, 00:09:28 »
Sorry for going off topic, but what case are you going to use with the ergodox?
Offline jonathanyu
« Reply #5 on: Fri, 06 September 2013, 00:16:22 »
I am still thinking of that, but most likely I will get one from http://www.shapeways.com/search?q=ergodox
« Reply #6 on: Fri, 06 September 2013, 11:46:11 »
I got mine from a vintage Dytcom keyboard. It also had the capacitor ...  ;D
Offline TD22057
« Reply #7 on: Fri, 06 September 2013, 12:34:32 »
Digikey has them in any quantity you want.  Put "resistor" in the search box, click through hole resistors, select 2.2k filter.  There are tons of options with various minimum quantities from 1-1000.  Here is one option:
http://www.digikey.com/product-detail/en/5-1625885-3/A105894CT-ND/3477431
Offline PepperPanda
« Reply #8 on: Fri, 06 September 2013, 15:22:18 »
The only reason I say get from Amazon is because Mouser and Digikey usually have a set price for shipping. So even if you're getting a small amount of components the shipping will be $4 or 5 bucks. But then again this is wallethack saving a buck or two means nothing here  :p
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #9 on: Fri, 06 September 2013, 16:15:39 »
digikey is my favorite because they offer pretty cheap shipping for small orders, they offer first class mail for lighter orders.
