Author Topic: KTB Pure Pro or Quickfire Stealth?  (Read 1740 times)
Offline pagosElite
  • This website clings to you.
« on: Thu, 05 September 2013, 23:34:19 »
Which one is more suited to my needs? I play Starcraft 2, type research essays, code once in a while, and will be taking the keyboard to and from school once in a while if I can get a eSports club up and running in my High School.
Offline terran5992
  • One With The Cup Rubber
Re: KTB Pure Pro or Quickfire Stealth?
« Reply #1 on: Thu, 05 September 2013, 23:43:37 »
Get a quickfire rapid.
More reliable and more durable
Offline pagosElite
« Reply #2 on: Fri, 06 September 2013, 00:16:18 »
How? I've heard much more good things about KBT...
Offline jonathanyu
« Reply #3 on: Fri, 06 September 2013, 00:20:08 »
pure pro is 60% board, quick fire stealth is TKL.
It really depend on which one you like more. TKL or 60%.
Offline pagosElite
« Reply #4 on: Fri, 06 September 2013, 00:23:57 »
Well thats what im wondering, whats better for my needs?
Offline dragonxx21
« Reply #5 on: Fri, 06 September 2013, 00:26:17 »
As a starcraft player, I can tell you right now that if you play Starcraft even semi-competitively, you will not be able to live without the function keys. Go for the QFS.
Keyboards Owned:
Realforce Topre 91 Key JIS Profile - Main
CM Quickfire Rapid Blue Switches
IBM Model M in Industrial Shell
Offline jonathanyu
« Reply #6 on: Fri, 06 September 2013, 00:32:53 »
I have never played starcraft, but I think a lot of game need to use function row, so I think TKL will be better for gaming.
