Author Topic: please help me with "keycaps direct"  (Read 3816 times)
Offline concept73
« on: Sat, 07 September 2013, 07:18:21 »
Can someone please explain this?
-I like how he has the green and the black, but i want red/black but cant get my head round his wording, any help would be appreciated!
I'm not sure what i means by "base set - black (ndy)"
http://keycapsdirect.com/marketplace.php
« Last Edit: Sat, 07 September 2013, 07:22:00 by AvJaB »
Poker 2 with reds
Soon to be a JD40 with reds
Re: please help me with "keycaps direct"
« Reply #1 on: Sat, 07 September 2013, 07:30:54 »
They have base sets and modifier sets. In the pic the green is the modifier. So what you want to order to get a black base and red modifier is 'base set black' and 'modifier set red'
There are also links to pdfs under the pic showing what keys are included with each set.
34465-0
Offline llovro
« Reply #2 on: Sat, 07 September 2013, 07:31:03 »
base set are alpha keys, F row and number row
modifiers are everything green that you see in that picture (spacebar, **** etc. etc.)
So if you want red/black colorway you should add to cart black base set and red modifier set.
I hope this helps
Edit: got ninja'd...
Offline concept73
« Reply #3 on: Sat, 07 September 2013, 07:36:00 »
Thanks for the advice guys! just was not sure of the wording of it :)
Poker 2 with reds
Offline concept73
« Reply #4 on: Sat, 07 September 2013, 07:37:00 »
Should look good on my poker 2 :D
Poker 2 with reds
Offline norbauer
  • Plz email shop@norbauer.com; I miss PMs sometimes
    • Ryan Norbauer's personal site
« Reply #5 on: Sat, 07 September 2013, 16:56:39 »
Incidentally, anybody know if it's possible to use any combination of these on a numpad, or do these just work for 80% and 60% boards?
« Reply #6 on: Sat, 07 September 2013, 17:01:25 »
Looks like there isn't an option for numpad kits, so I'd assume not.
Offline norbauer
« Reply #7 on: Sat, 07 September 2013, 17:17:24 »
K. Thought as much, but just wanted to make sure I wasn't missing something.
Offline Rule16
  • R.I.P. SmallFry
« Reply #8 on: Sun, 08 September 2013, 00:11:32 »
You can, every key in DSA every key is the same profile except for f and j. Not sure If I read the question right though.
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
