Author Topic: Looking to get my first mechanical  (Read 1547 times)
Offline Tempiz
  • Buckling Springs <3
« on: Sat, 07 September 2013, 14:23:32 »
Well, I am thinking of getting a Model M. I have used mx blues and reds before, But I want to own my own. I peronally own a rubber dome unfortunetly. I was thinking of getting a blue switch keyboard but the model m really has my eye. What do you think?
I cant be separated from my Model M
Re: Looking to get my first mechanical
« Reply #1 on: Sat, 07 September 2013, 14:32:07 »
Buckling spring switches aren't really comparable to cherry switches. If you want a model m, but don't want to try and find a good one, Unicomp makes a very good replica.
Offline Tempiz
« Reply #2 on: Sat, 07 September 2013, 14:33:24 »
Yeah, I  know there not all that comparable. And thanks for the suggestion!
Offline Clicky
« Reply #3 on: Sat, 07 September 2013, 14:36:39 »
Yes.  You should.  IMO the buckling springs of a Model M (typing on one now) provide one of the best typing experiences.  If you game a ton you might want to look into some other cherry mx options, but the model m does fine here too.
« Reply #4 on: Sat, 07 September 2013, 14:37:05 »
Man, for a second there I thought you were called 'Tempz'
« Reply #5 on: Sun, 08 September 2013, 22:45:15 »
Welcome to Geekhack!
Nothing wrong with a Model M - I have two :)
Awesome choice for a first mechanical, although your choice in custom keycaps will be somewhat limited.
Offline Gunni
« Reply #6 on: Mon, 09 September 2013, 04:13:01 »
Welcome to GH! I'm new here myself.
Anyway, my first mechanical keyboard (which I only got a couple of days ago) is a CM STORM Quickfire TK with Cherry MX Brown switches, it also comes in Blue and Red. I highly recommend it!
I am actually trying to get a hold of a Model M myself right now, I've heard they're great.
CM Storm Quickfire TK w/ Browns HHKB Pro 2
Offline Emospence
« Reply #7 on: Mon, 09 September 2013, 04:26:26 »
Are you going to be mainly working on it?
Gaming?
Both?
Keyboards: Topre Realforce 87UW 55g x 2
Mice: Zowie EC1 eVo CL x 2
Mousepads: Artisan Hien VE x 2, Razer Mantis Speed
