Author Topic: Removing key cap from costar stabilizer?  (Read 8254 times)
Offline pagosElite
  • This website clings to you.
« on: Sat, 07 September 2013, 21:25:37 »
How do i remove a key from a costar stabilizer (pulling the thin metal out of the white thing)?
Offline Xenderwind
Re: Removing key cap from costar stabilizer?
« Reply #1 on: Sat, 07 September 2013, 21:27:30 »
Pull the keycap off the switch.
Push keycap to one side (left or right).
Lift.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline pagosElite
« Reply #2 on: Sat, 07 September 2013, 21:40:39 »
Lift.
Thanks! Theres no point in putting orings on the +'s with the stablizers on them right? Just the middle one right?
« Last Edit: Sat, 07 September 2013, 21:52:49 by pagosElite »
Offline BliTzKiN
« Reply #3 on: Sat, 07 September 2013, 21:52:52 »
Lift.
Thanks! Theres not point in putting orings on the +'s with the stablizers on them right? Just the middle on?
That is right, just setting the O-rings in the middle one (the one that mounts to the swtich) will do since its costars and the sides don't come into contact with anything at all.
Offline Rule16
  • R.I.P. SmallFry
« Reply #4 on: Sat, 07 September 2013, 23:10:15 »
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
Offline Hyde
  • White Tofu Extraordinaire
« Reply #5 on: Sun, 08 September 2013, 21:10:05 »
Ignore the intro music, otherwise it's a good video.
« Last Edit: Mon, 09 September 2013, 10:52:51 by Hyde »
