Author Topic: Plastic Primer For Painting QFR Case  (Read 3177 times)
Offline dragonxx21
« on: Sun, 08 September 2013, 01:50:22 »
So I've been thinking about getting a replacement case for my QFR that's hopefully coming this week. Since I was going to get a replacement case, I thought I might as well paint it. After a few hours of looking for a plastic primer, I finally found a few products that could work. I'm not sure which would work best with the QFR case, so I decided to ask you guys. I have access to two primers, black or red, as well as an adhesion promoter. Has anyone had any experience with any or all of these products and mind telling me how you feel about the products?
Keyboards Owned:
Realforce Topre 91 Key JIS Profile - Main
CM Quickfire Rapid Blue Switches
IBM Model M in Industrial Shell
Offline dragonxx21
Re: Plastic Primer For Painting QFR Case
« Reply #2 on: Sun, 08 September 2013, 12:58:56 »
http://geekhack.org/index.php?topic=47490.0
http://geekhack.org/index.php?board=152.0
Thank you, but I'm posting here as I've already talked to people from there, and have been told to just post in the DIY subforum.
Keyboards Owned:
Offline dgreekstallion
  • B.S. Fiend
Recent keyboard fanatic.
Model F-122 convert.
Offline Tarzan
  • formerly known as Greystoke
« Reply #4 on: Fri, 13 September 2013, 21:29:26 »
I used Rustoleum to paint my CM Trigger, but I didn't use primer or adhesion booster.  No issues with paint sticking, I'm pretty impressed with Rustoleum products.
One note I've seen on the QFR painting thread; a solid color primer can help darken/lighten a topcoat color, depending on your desired goal.  Something to keep in mind as you plan out the paint job.
Offline dragonxx21
« Reply #5 on: Fri, 13 September 2013, 21:36:48 »
Alright, thanks for the suggestions guys.
Keyboards Owned:
