Author Topic: Leopold FC660C Loose Mini-USB Connector  (Read 5030 times)
Offline Hypersphere
« on: Sun, 08 September 2013, 10:34:06 »
I've noticed that the mini-USB connector on my Leopold FC660C is loose and wobbles more than the connector on my other keyboards, including my Leopold FC660M. This is especially noticeable with the cable that was supplied with the keyboard, but it still occurs with premium-quality cables. Has anyone else noticed this with their FC660C keyboards?
Offline AuRinBei
Re: Leopold FC660C Loose Mini-USB Connector
« Reply #1 on: Sun, 08 September 2013, 11:56:53 »
No, mine doesn't wobble much at all.
87u || Poker 2
Offline Sniping
« Reply #2 on: Sun, 08 September 2013, 12:48:24 »
Mine wobbles when I play with the cable, but I don't see how it can be wobbling when you're typing.
Offline Hypersphere
« Reply #3 on: Sun, 08 September 2013, 13:51:49 »
Yep, I should have said, "I can wobble it" rather than implying that it wobbles on its own or when I am typing.
Offline reziak
  • Topre/60% Enthusiast
« Reply #4 on: Mon, 27 January 2014, 16:33:44 »
Necroing this thread, but my new FC660M has a pretty loose connector. The cable stays in and doesn't lose connection - it just wobbles A LOT. The cable that came with it is particularly bad....But some of my other cables are better.
HHKB Pro 2 | FC660C | HHKB Pro 2 Type-S
Offline dante
« Reply #5 on: Fri, 30 May 2014, 13:04:38 »
snug!
« Last Edit: Tue, 03 June 2014, 14:47:55 by dante »
Offline dante
« Reply #6 on: Fri, 30 May 2014, 14:56:27 »
Nice keyboard!
« Last Edit: Tue, 03 June 2014, 14:48:11 by dante »
