Author Topic: Shine 3 TKL or fullsize?  (Read 4340 times)
Offline C5Allroad
  • Formerly HUNTERANGEL121
« on: Sun, 08 September 2013, 14:07:32 »
I'm deciding between the TKL or fullsize version. I don't know which I should buy. I'm starting to think that a TKL would be better for gaming minus in planetside since I kinda of have to use the numapd to talk in various types of chats but I can always buy a keycool 22 key numpad and put next to my mouse mat. Which should I buy?
Offline Moosecraft
  • HHKB Pro
Re: Shine 3 TKL or fullsize?
« Reply #1 on: Sun, 08 September 2013, 14:09:12 »
I'm a TKL man myself mostly for the looks.
Offline GeeGee
  • ㅈ ㅈ
« Reply #2 on: Sun, 08 September 2013, 15:42:13 »
Need a numpad? Get a full size
Don't need a numpad? Get a TKL
It's really obvious..
Ducky Shine 2 with Blues
Poker 2 with Reds
KMAC Korean Custom with Clears
ReΛlforce 87u 55g
456GT
« Reply #3 on: Sun, 08 September 2013, 22:52:40 »
This, really.  TKL is more ergonomic in that it allows you to place the mouse closer, and not have to have your arms sticking out too far.
Although I do switch between HHKB and Model M at home :))
Offline Emospence
« Reply #4 on: Mon, 09 September 2013, 03:49:46 »
Personal preference, isn't it?
Myself, I'm a full size kinda guy :)
Keyboards: Topre Realforce 87UW 55g x 2
Mice: Zowie EC1 eVo CL x 2
Mousepads: Artisan Hien VE x 2, Razer Mantis Speed
Offline mapple
« Reply #5 on: Mon, 09 September 2013, 05:49:35 »
well, myself very much appricated full size, but since few weeks i'm crazy about shine 3 tkl. Reason i had possibility to check filco tkl in work and for gaming (friend from work borrowed it). I was almost convinced that without digits on right side i'll be done (i mean half of my work depends on them) but it's not true...... and boy oh boy about llllllllllllllllllllllooooooooot of place free on right side:D. Thanks to that disstance for hand is significantly lower and both gaming and work is way better.
In God We Trust
Offline Grim Fandango
« Reply #6 on: Mon, 09 September 2013, 08:00:48 »
Personally I like tenkeyless or smaller.
When I center a full-size keyboard in front of me, I find that my mouse is at an awkwardly large distance from my body. When I need the numpad, I simply have a USB one that I hook up.
I also just like the look of tenkeyless. But even if I did not , I would still go tenkeyless.
« Last Edit: Mon, 09 September 2013, 08:03:08 by Grim Fandango »
Offline Danule
« Reply #7 on: Mon, 09 September 2013, 09:32:19 »
I used to love fullsize but since switching i have found that having my shoulder not as stretched out to the side is more benefitial than the numpad. Ive gotten used to using the numbers at the top.
45g Brown Brown Blue
Offline SeriouSSpotS
  • 60% is love, 60% is life
« Reply #8 on: Mon, 09 September 2013, 10:41:00 »
Depends on your needs, we cannot tell you otherwise.
Offline Altis
« Reply #9 on: Mon, 09 September 2013, 15:19:13 »
I'm waiting for a TKL Shine 3, personally, as I have a few full size keyboards already and find that having my hands in front of me, in-line with the monitor, is much better ergonomically.  Personally, I find TKL still wastes space, and 60%ish is best, although a lot of them seem to have drawbacks in one way or another.
Best to consider which keys you can and can't live without, and go from there.  If you don't do much spreadsheet action, you'll likely benefit from a smaller board.  Just my 2 cents worth!
As a side note, I'm hoping the TKL Shine 3 comes out soon and is quickly available in Canada... itchin for a new board!  (and the QFR always looks so tempting)
Offline mapple
« Reply #10 on: Mon, 09 September 2013, 16:20:45 »
mechnicalkeyboards will have them and pchome global they're very fast with sending seriously... unless u waiting for some Canadian reseller than it might take a while.
In God We Trust
Offline Altis
« Reply #11 on: Mon, 09 September 2013, 18:28:04 »
You'd be surprised.  Canada Computers has a decent selection, lets me take them out and try them (as keyboards with the same switches can still feel vastly different).
Some online places are very good to Canadians, too, so we don't get royally bent-over on duty charges.
Offline C5Allroad
« Reply #12 on: Mon, 09 September 2013, 18:40:21 »
Ooooh nice!
Offline Altis
« Reply #13 on: Mon, 09 September 2013, 18:59:58 »
Also, I just noticed via another thread that mechanicalkeyboards has the TKL Shine 3 listed, although it hasn't been released yet.  The photo is cropped from a full-sized Shine 3 board.
In case your purchase was imminent.
Offline C5Allroad
« Reply #14 on: Mon, 09 September 2013, 19:23:52 »
Great! Now I can't decide over the keycool 87key backlit.
I have to stay off the internet for a while before I get any ideas lol. :p
http://www.kc-keycool.com/en/product.php?mod=detail&id=16
Offline Altis
« Reply #15 on: Mon, 09 September 2013, 20:11:57 »
Story of my life!
Offline C5Allroad
« Reply #16 on: Mon, 09 September 2013, 20:18:58 »
I might want a tenkeyless and then buy the keycool 22 key num pad with all sorts of functions and eave it off to the side of my mouse mat.
