Author Topic: Issue with keyboard  (Read 1442 times)
Offline 1391406
Issue with keyboard
« on: Sun, 08 September 2013, 14:18:08 »
I've been having an issue with my Chicony holding down arrow keys at random. It wasn't often enough to render it unusable. So, I tried swapping adapters, but no luck. So, I just dealt with it. However, recently, I noticed the CTRL key was randomly actuating and doing it often enough that I couldn't really use the keyboard. I sprayed some compressed air into the switch to no avail. I opened up the board and toyed with the 4-pin power connector. I noticed even when I UNPLUGGED IT, the CTRL key would still randomly fire. Hence, I figured it was the cable. However, on a whim, I unscrewed the grounding wire and plugged the cable back in. Voila. No more random actuating keys. Hence, this post.
Can anyone think of a reason why the grounding wire would cause this?
« Last Edit: Sun, 08 September 2013, 14:30:02 by 1391406 »
Re: Issue with keyboard
« Reply #1 on: Sun, 08 September 2013, 22:51:22 »
Short circuit?
Grounding wire touching something it shouldn't?
Offline 1391406
« Reply #2 on: Sun, 08 September 2013, 23:59:10 »
Nothing other than the ground screw that was fastening it in place.
