Author Topic: Need help with sleeving a coiled cable  (Read 2828 times)
Offline BlueBär
« on: Sun, 08 September 2013, 15:35:41 »
I bought this 3m USB coiled cable because I love coiled cables, and I thought why not sleeve it? I know that it was going to be a bit of a pita but not this bad...
So doing the first third was actually quite ok, then the tape I put around the tip came off, I continued on and I have about half of it done but I'm absolutely stuck now. The last ~10 coils I tried using wax to kind of lubricate it, but that didn't do much at all. I also tried warm water (because I thought the paracord might expand because of the warmth) but that made it worse. I tried pulling on the sleeve itself as well, but that didn't do anything. This is my current progress:
34581-0
Can anybody with a bit more sleeving experience give me tips?
Offline phetto
  • HHKB JP
Re: Need help with sleeving a coiled cable
« Reply #1 on: Sun, 08 September 2013, 15:36:15 »
Ask paranoid, he knows how to do it. :)
Offline BlueBär
« Reply #2 on: Sun, 08 September 2013, 15:40:51 »
Whoa that was a quick reply :)
I asked pexon since he does coiled cables, but he didn't answer, and paranoid does just normal cables.
« Reply #3 on: Sun, 08 September 2013, 15:42:07 »
Paranoid does coiled cables too :)
Offline BlueBär
« Reply #4 on: Sun, 08 September 2013, 15:45:21 »
Oh ok, didn't know that, I'll shoot him a message.
Offline TheFlyingRaccoon
  • HHKB Pro
  • Cable maker and future engineer
« Reply #5 on: Sun, 08 September 2013, 15:58:34 »
Good luck with that! Coiled cables are pretty hard to sleeve but if you stretch the cable out some it might help.
HHKB Pro 2   SmallFry Keyboard
