Author Topic: [WTS] Custom order Phantom  (Read 2281 times)
Offline danielucf
  • Horrible Mailman
  • Trade Count: (0)
  • Hmmmm beer.
« on: Mon, 09 September 2013, 16:22:55 »
I will build one Ansi-150 Phantom in a CM Quickfire Rapid case for the first luck buyer.
Options:
Switches: MX Greens, Blacks (vintage if that matters to you), Reds, or Blues
Stickers: Yellow, Pink, White, Black, green, or can easily get other colors
Springs: 62g, 55g, stock, or can get others
Lube: Springs will have Victorinox (unless you want nothing, or a different lube) stems will depend what switch type you request but I have several types of Krytox, Tribolube 71, and some Teflon lubes that dry.
Removable cable mod: I am pretty confident I can rig the Phantom to use the external USB port of the QFR
Paint: I am not that good at painting I have learned (or flaws in other's pictures don't really show up and I'm decent) so I'll do plastidip in any color that amazon carries since it is easy to repair and hard to screw up, otherwise I don't want to modify the case top
Price is negotiable depending on what options you would like, and where you are located regarding shipping costs. I am guessing in the range of $175-250. Send PMs with any inquiries.
« Last Edit: Mon, 09 September 2013, 18:33:25 by danielucf »
Offline TheFlyingRaccoon
  • HHKB Pro
  • Trade Count: (0)
  • Cable maker and future engineer
Re: [WTS] Custom order Phantom
« Reply #1 on: Mon, 09 September 2013, 16:26:43 »
Good luck with the sale!
HHKB Pro 2   SmallFry Keyboard
  • Trade Count: (0)
« Reply #2 on: Mon, 09 September 2013, 16:28:34 »
Sounds like a good deal!! Too bad I don't need another phantom ;)
Offline danielucf
  • Horrible Mailman
  • Trade Count: (0)
  • Hmmmm beer.
« Reply #3 on: Mon, 09 September 2013, 16:34:27 »
Thanks. After comparing my soldering/keyboard tuning to a Korean assembled board I acquired a bit ago I can see that I've come a long way, and really don't see a need for me to buy a fully assembled board from a Korean ever again. I can do it quite well myself now  :thumb:
Sure you do, you need one assembled by me  ;)
  • Trade Count: (0)
« Reply #4 on: Mon, 09 September 2013, 16:49:24 »
I only want phantoms with the complete right side utilized so unless you want to take a hacksaw to that QFR top :P
Offline danielucf
  • Horrible Mailman
  • Trade Count: (0)
  • Hmmmm beer.
« Reply #5 on: Mon, 09 September 2013, 17:37:42 »
Is it still possible to buy those tops? I have some dremel attachments I've been meaning to try out...
Offline strafe
  • Trade Count: (0)
    • Strafe's Blog
« Reply #6 on: Mon, 09 September 2013, 19:13:43 »
PM Sent!
Freebird WKL (Blacks Clear-Tops), iKBC F-104 (Blacks) and more!
Offline xSpartanCx
  • Trade Count: (0)
« Reply #7 on: Mon, 09 September 2013, 19:44:11 »
I wasn't aware that you could use the keys around the arrows... Now I really want a Phantom :D
