Author Topic: Blank keycaps  (Read 4126 times)
Offline C5Allroad
  • Formerly HUNTERANGEL121
Blank keycaps
« on: Tue, 10 September 2013, 20:54:15 »
Hey guys I really like the idea of someone not being able to use my computer unless they can touch type. Where can I buy blank keycaps? If I were to buy white would they turn black or brown from my fingers? My only weakness is the number row symbols.  :p
« Last Edit: Tue, 10 September 2013, 20:59:33 by HUNTERANGEL121 »
Re: Blank keycaps
« Reply #1 on: Tue, 10 September 2013, 21:00:53 »
Nothing to stop them plugging in a different keyboard or just using the mouse.
Offline C5Allroad
Re: Blank keycaps
« Reply #2 on: Tue, 10 September 2013, 21:04:40 »
Who says that my friends bring extra keyboards? Hehe.
Offline lcs
  • Lover of Grape Drank
  • はやく
Re: Blank keycaps
« Reply #3 on: Tue, 10 September 2013, 21:22:24 »
wasd has blank sets. Feng, imsto and qtan also have them.
Group buys in general have blanks.
Offline C5Allroad
Re: Blank keycaps
« Reply #4 on: Tue, 10 September 2013, 21:31:36 »
Oh thanks I can't till I order them. :)
Offline therecorder
Re: Blank keycaps
« Reply #5 on: Tue, 10 September 2013, 21:44:22 »
Depends on whether you want to have friends :)  On a side note, I touch type (not fast, due to OCD/dyslexia), but I also smoke and often use the phone while on the computer.  Blanks, especially on my main computer, are a real pain.
Re: Blank keycaps
« Reply #6 on: Wed, 11 September 2013, 01:09:47 »
Offline Reomero
  • Manual breather
Re: Blank keycaps
« Reply #7 on: Wed, 11 September 2013, 03:45:45 »
I have a blank white set for daily use and yeah they will tend to show dirt/sweat/whatever more easily. For me personally, they still look "white" unless you look at them very closely.
Offline C5Allroad
Re: Blank keycaps
« Reply #8 on: Wed, 11 September 2013, 20:56:06 »
How would one clean them?
Offline eth0s
  • Peace & Love
Re: Blank keycaps
« Reply #9 on: Wed, 11 September 2013, 21:09:43 »
White keycaps do not get overly dirty with normal use.  You would need to have dye on your hands to stain the keycaps.  Normal rules for eating at your keyboard apply to white caps, same as black ones.
Offline C5Allroad
Re: Blank keycaps
« Reply #10 on: Thu, 12 September 2013, 16:17:42 »
I never bring food into my computer room, I sometimes bring Gatorade or lemonade with me into the computer while on the keyboard but that's irrelevant to being dirty. I'm saying from normal gamer sweat and usage. :)
Offline lcs
  • はやく
Re: Blank keycaps
« Reply #11 on: Thu, 12 September 2013, 16:19:00 »
Offline C5Allroad
Re: Blank keycaps
« Reply #12 on: Thu, 12 September 2013, 18:51:42 »
Would it be white like new? Or close to it?
Re: Blank keycaps
« Reply #13 on: Thu, 12 September 2013, 18:57:39 »
Pretty close to it.
You won't get many stains on keycaps that won't soak off, and denture tabs help to get rid of oil and dirt.
Just put about 3 in a container of warm water, soak the keycaps until the water turns clear (or turns brown, depending on how dirty the keycaps were), and then spread them out on newspaper or similar to dry.
There are a couple of threads around here that explain it similarly.
Offline C5Allroad
Re: Blank keycaps
« Reply #14 on: Thu, 12 September 2013, 20:54:24 »
Ok. Now I need to find a PCB mounted board that's TKl. I've been looking all over....
Offline ComradeSniper
  • HHKB Pro
Re: Blank keycaps
« Reply #15 on: Thu, 12 September 2013, 23:14:44 »
If you want PCB mounted switches for the ability change them easier, you could always buy a Phantom or similar TKL board with a custom plate here on the classifieds.
Offline C5Allroad
Re: Blank keycaps
« Reply #16 on: Fri, 13 September 2013, 20:55:27 »
Hmmm I'll be looking around then. :)
