Author Topic: Help : LZ-S pause led is on?  (Read 2295 times)
Offline rao2100
« on: Wed, 11 September 2013, 08:07:07 »
I have a LZ-S and cant figure out why my pause led is always lit up?
Anyone has any pointers?
« Last Edit: Mon, 16 September 2013, 09:51:55 by rao2100 »
| KMAC LE Vintage Blues | LZ-S Ergo Clears | Filco TKL MJ2 Ninja Reds | CM QFR - Blues | IBM Model M SSK 1991 |
Offline Xenderwind
Re: LZ-S pause led is on?
« Reply #1 on: Wed, 11 September 2013, 08:10:16 »
hmm on my gon i remember hitting fn then I think it was either scroll lock or pause and it would change the led's.  no idea if its the same though.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline MKULTRA
  • telling it how it is
« Reply #2 on: Wed, 11 September 2013, 09:04:42 »
Try pressing Menu + Caps Lock a couple times.
Offline rao2100
« Reply #3 on: Wed, 11 September 2013, 09:18:46 »
Did that didnt work  :'(
Offline rao2100
« Reply #4 on: Thu, 12 September 2013, 18:13:06 »
Still no luck. Anyone has pointers?
Offline rao2100
Re: Help : LZ-S pause led is on?
« Reply #5 on: Mon, 16 September 2013, 23:02:44 »
Any LZ-S owners?
Offline ___q
« Reply #6 on: Mon, 16 September 2013, 23:19:13 »
I have an LZ-S, but the only thing I know how to do with it is press scroll lock to turn on or off all of the LEDs, nothing pause-led-specific, sorry :(
(and type normally, of course)
« Reply #7 on: Mon, 16 September 2013, 23:37:34 »
I have an LZ-S. you can turn it off with the aikon software. it doesn't indicate anything specific. I just keep mine on...
Offline rao2100
« Reply #8 on: Tue, 17 September 2013, 19:27:51 »
Thanks for the replies guys. I think I am starting to live with it :)
