Author Topic: Fix broken key on AT102W?  (Read 2498 times)
Offline patmok
« on: Mon, 01 December 2008, 10:37:16 »
Hello,
I just got a Dell AT102W and some keys are not working, so i took it apart to try to see if i can see what is wrong. But I could not seperate the metal plate where the switches are from the PCB (I removed all visible screws) is there a way to do this? The broken key switch does not look damaged physically when I remove the keycap.
pat
Offline lam47
« Reply #1 on: Mon, 01 December 2008, 11:24:14 »
The only way to remove the metal from the PCB is to de solder every switch.
What I would do is de solder the faulty ones and relegate them to some unused keys.
I don't remember ever using * for example.
You could try opening the switch to see what's up but they are very delicate and can be easily broken.
Someone else more knowing may have a better idea but its what I do. Just move the faulty ones.
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline lowpoly
« Reply #2 on: Mon, 01 December 2008, 13:50:35 »
No way to remove a switch without de-soldering, IIRC.
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
« Reply #3 on: Mon, 01 December 2008, 18:19:54 »
Try cleaning the switches.
