Author Topic: Pure pcb help  (Read 2297 times)
Offline turtle
Pure pcb help
« on: Fri, 13 September 2013, 08:31:20 »
Hello fellow gh. I have a pure pcb and a acrylic case from Ali. I'm running into an issue with the pure pcb fitting into the acrylic case i have due to dip switch led. If I remove the led off will my pcb still work? And will the rest of the led still work? Never worked on a pure pcb before and I'm wondering if that would be an issue. Thanks for the help!
Re: Pure pcb help
« Reply #1 on: Fri, 13 September 2013, 08:39:12 »
Yes, that is the Caps Lock LED. You can remove it, and the board will still work fine. In fact, you can replace it with an in-switch LED if you want! :)
Offline turtle
Re: Pure pcb help
« Reply #2 on: Fri, 13 September 2013, 09:06:15 »
Sweet! Thanks guru jdcarpe! Seems like you always have the answers
