Author Topic: Cherry Classic Line G83-6105  (Read 1569 times)
Offline SOROBORU88
« on: Fri, 13 September 2013, 12:16:00 »
Hello everyone,
sorry for bothering you. I have a chance to buy this keyboard : http://www.preiscompany.com/catalog/product/view/id/2215/s/cherry-classic-line-g83-6105-tastatur-ps-2/
Is there someone, who is able to find out by its number, that the picture matches the real keyboard? I asked the seller about the small enter and the answer was positive.
Assuming, that this keyboard has cherry compatible keycaps of course.
Thank you very much.
Offline MTManiac
Re: Cherry Classic Line G83-6105
« Reply #1 on: Fri, 13 September 2013, 12:18:22 »
link isn't working for me  :-[
« Reply #2 on: Fri, 13 September 2013, 12:18:57 »
G83 is rubberdome
Offline SOROBORU88
« Reply #3 on: Fri, 13 September 2013, 12:56:29 »
Here's the picture :)
Offline SOROBORU88
« Reply #4 on: Fri, 13 September 2013, 12:58:26 »
I know it should be rubberdome. I already have one of those, but the layout doesn't fit my main keyboard and I need some keycaps for the final setting.
All I ask is, if it is possible to figure out, if the keyboard on the picture will be the same, according to the product number. And if the keycaps are cherry compatible, and also cherry profiled.
« Reply #5 on: Fri, 13 September 2013, 13:02:11 »
Offline SOROBORU88
« Reply #6 on: Fri, 13 September 2013, 13:38:38 »
I need those keycaps, not the boards. I bought and old G91 with rubberdome cherry switches and salvaged the keycaps. The keyboard itself collects dust under my house. I plan the same with this keyboard. I will salvage the modifier keycaps. They should fit to my czech base keycaps.
Offline SOROBORU88
« Reply #7 on: Fri, 13 September 2013, 13:39:54 »
Me dammit! I read the other thread. This keyboard is useless :( Dammit again. Thank you very much, fellow wizard.
