Author Topic: New K95 a candidate for full key swap?  (Read 2376 times)
Offline flomofo
« on: Fri, 13 September 2013, 20:00:59 »
Since the new k95 is mechanical everywhere except for the dumb add-on media keys is it possible to do a full swap out to white key caps?
Also wondering if the lighting would still look good if PBT caps are sued.
Offline flomofo
Re: New K95 a candidate for full key swap?
« Reply #1 on: Fri, 13 September 2013, 20:16:40 »
And also is it possible with the newer k70 or 60 series etc?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Fri, 13 September 2013, 20:23:22 »
For current model Corsairs, all are replaceable with aftermarket caps except the spacebar since they use a nonstandard size. The 1.5 Ctrl keys may be challenging depending on what sets you are after replacing the stock set with.
Regarding the backlighting, thin PBT/ABS will give a paper lantern look, the thicker Cherry profile caps not so much.
Offline flomofo
« Reply #3 on: Sat, 14 September 2013, 16:36:36 »
Thanks for the reply.
I was thinking about using thicker white colored caps or PBT thick white caps with side lettering and just using the white lighting underneath the keys as it still has a cool effect due to the design of the keyboard.
Offline terran5992
  • One With The Cup Rubber
« Reply #4 on: Sun, 15 September 2013, 04:17:16 »
IMO, I don't like the way light shines on pbt caps
