Author Topic: IBM SpaceSavers  (Read 4752 times)
Offline prasopes
IBM SpaceSavers
« on: Sat, 14 September 2013, 16:29:04 »
I'd love to have a desktop keyboard with a TrackPoint. Since the IBM SpaceSaver and SpaceSaver II keyboards use rubber domes instead of buckling springs, should I even consider buying one? I've read that the early Thinkpads had quite pleasant rubber dome keyboards, so perhaps the old SpaceSaver keyboard could be similar?
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
Re: IBM SpaceSavers
« Reply #1 on: Sat, 14 September 2013, 16:30:59 »
I once had one... and it felt terrible.. so terrible that I couldn`t use it for some minutes and instantly resold it...
Offline ch_123
Re: IBM SpaceSavers
« Reply #2 on: Sat, 14 September 2013, 16:34:06 »
The M4-1 (i.e. original Space Saver) is ok. The problem is that the old Trackpoint II design was not nearly sensitive enough for use on the sort of resolutions that are common on modern monitors.
Offline hoggy
  • * Ergonomics Moderator
Re: IBM SpaceSavers
« Reply #3 on: Sat, 14 September 2013, 16:34:14 »
I'm with snoopy on this one. I think if you get one nib then you'll be okay for a while, but not forever.
The layout is superb, however, I really want a mechanical version.
Offline prasopes
Re: IBM SpaceSavers
« Reply #4 on: Sat, 14 September 2013, 16:45:34 »
So the Space Saver II is substantially worse? I like the fact that the Trackpoint on these has three buttons as I use the middle button a lot for scrolling.
Offline ch_123
Re: IBM SpaceSavers
« Reply #5 on: Sat, 14 September 2013, 16:50:14 »
I can't comment personally, I only have experience of the first one. The II will have a better tracpoint though (I think it uses the Trackpoint IV)
« Last Edit: Sat, 14 September 2013, 17:56:16 by ch_123 »
Offline snoopy
  • The Flying Ace
Re: IBM SpaceSavers
« Reply #6 on: Sat, 14 September 2013, 17:09:15 »
Get the original spacesaver with buckling springs and try to forget the trackpoint. Or go fullsize...
Offline terran5992
  • One With The Cup Rubber
Re: IBM SpaceSavers
« Reply #7 on: Sun, 15 September 2013, 03:40:23 »
^^ this
Buckling springs are the best switches ever invented.
Offline hoggy
Re: IBM SpaceSavers
« Reply #8 on: Sun, 15 September 2013, 04:44:42 »
After re-reading my post - my comments are about the key feel / rubber domes.  Trackpoint is fine, although it could be 'faster'
Offline esoomenona
  • Gnillort?
Re: IBM SpaceSavers
« Reply #9 on: Sun, 15 September 2013, 09:12:34 »
Get a M13 and mod it down to a smaller size? There is one for sale for a ridiculously good deal right now, and I'm willing to help you with the price. I just want the caps.
Offline E TwentyNine
    • Some of My Keyboards
Re: IBM SpaceSavers
« Reply #10 on: Sun, 15 September 2013, 14:40:38 »
The buckling spring one (aka SSK) is a "Space Saving Keyboard".  The later ones are "Space Saver Keyboards".
Re: IBM SpaceSavers
« Reply #11 on: Sun, 15 September 2013, 14:43:30 »
I had considered doing this with one of my M13's.   But, the main reason I like tenkeyless is to leave room for a mouse.  If I have a keyboard with a trackpoint there's no real reason to save space for the mouse.
Offline esoomenona
  • Gnillort?
Re: IBM SpaceSavers
« Reply #12 on: Sun, 15 September 2013, 20:35:05 »
I was thinking a 60% or 75% with a trackpoint might be nice to travel with.
Offline 0100010
  • Not Sure
Re: IBM SpaceSavers
« Reply #13 on: Sun, 15 September 2013, 21:10:02 »
Would not suggest to cut down an M13, get a Unicomp with a trackpoint to mod instead.
Re: IBM SpaceSavers
« Reply #14 on: Sun, 15 September 2013, 21:25:49 »
That is a better idea in general, however the problem with cutting down a unicomp is the controller is connected above the number pad and how it is connected.  See this thread: http://geekhack.org/index.php?topic=40006.75
I don't recall how samwisekoi got around that exactly (no pics) but it seems like he did.  It's just not as clean an operation as cutting down an IBM M.
I have a few of those IBM mice with the trackpoint in them, I could see putting something together with a standard M and those internals, or snagging the pointer out of a later space saver, but I have not looked into it beyond speculation.
Offline esoomenona
  • Gnillort?
Re: IBM SpaceSavers
« Reply #15 on: Sun, 15 September 2013, 21:35:53 »
Why not? A Unicomp because it could be said to be more "throwaway-able"?
Re: IBM SpaceSavers
« Reply #16 on: Sun, 15 September 2013, 22:04:31 »
Sure, If you break it, they can just make more.
Offline terran5992
Re: IBM SpaceSavers
« Reply #17 on: Mon, 16 September 2013, 02:58:25 »
Anyone knows where i can buy a spacesaver model m for less than $200
Offline snoopy
  • The Flying Ace
Re: IBM SpaceSavers
« Reply #18 on: Mon, 16 September 2013, 03:51:56 »
With patience on ebay...
Offline terran5992
Re: IBM SpaceSavers
« Reply #19 on: Mon, 16 September 2013, 04:29:22 »
Gonna be a long time D:
Offline snoopy
  • The Flying Ace
Re: IBM SpaceSavers
« Reply #20 on: Mon, 16 September 2013, 08:27:19 »
or try it here in classifieds... maybe you have luck...
Offline terran5992
Re: IBM SpaceSavers
« Reply #21 on: Mon, 16 September 2013, 08:43:24 »
Usually the ssk available for sale in the classifieds usually cost around a million dollars
Offline snoopy
  • The Flying Ace
Re: IBM SpaceSavers
« Reply #22 on: Mon, 16 September 2013, 09:18:16 »
ok, special offer for you: you can have one of mine for half a million dollar. that saves you 50% :D
Re: IBM SpaceSavers
« Reply #23 on: Mon, 16 September 2013, 09:29:02 »
I'll sell you my genuine 1992 industrial SSK for half that.
