Author Topic: Auxiliary Spring Mod on Topre-Switch Keyboards?  (Read 3260 times)
Offline Hypersphere
« on: Sun, 15 September 2013, 11:12:44 »
I recently bought a Leopold FC660C, which has 45-gram Topre switches. However, the spacebar has an auxiliary compression spring that fits around the outside stem of the switch. According to EK, this spring adds about 5 cN to the actuation pressure of the switch and also aids in the rebound of the spacebar. This spring can easily be removed and placed on other keys if desired. I like the slightly heavier feel of the spacebar, and I thought it could be a good idea to make all of the keys slightly heavier.
Therefore, would it be possible to do an "auxiliary spring mod" on a Topre board by acquiring a set of these 5 cN springs and installing them on each switch? The object would be an easy conversion of, say, a 45-gram Topre board to a 50-gram Topre board without resorting to the much more difficult method of swapping out the rubber domes. Furthermore, if one had 10 cN springs, the conversion should result in changing a 45-gram board to a 55-gram board.
My motivation for trying this is that it would provide an easily reversible way to change the actuation/rebound forces on a Topre board. For example, at present EK has some 45-gram RF 87u boards in stock, but the 55-gram boards are out of stock until November. I would prefer not to wait, and I am also not sure if I would prefer a 55-gram over a 45-gram board.
However, this method of modifying a Topre switch must be too easy to be true, and I suppose the characteristics of an auxiliary spring modded board would not be the same as actually changing the rubber domes.
Nevertheless, if this seems like an idea worth trying, does anyone know where I could find 5-10 cN springs that would fit Topre stems? If such springs are not readily available, where could I have some made in small lots for a reasonable price? I would only need enough for one to a few keyboards.
Thanks for any insights and suggestions you might have.
Offline therecorder
Re: Auxiliary Spring Mod on Topre-Switch Keyboards?
« Reply #1 on: Sun, 15 September 2013, 11:30:33 »
I'm interested to see the replies to this.  Can't recall anyone else posing these questions.
« Reply #2 on: Sun, 15 September 2013, 11:33:24 »
Possible? Probably.
Where can you source the springs from though? Most Topre parts are notoriously hard to get.
Offline Sniping
« Reply #3 on: Sun, 15 September 2013, 13:25:42 »
The size of the spring has to be very exact for the 1x keys. If it's too big it won't fit but if it's too small the spring will get caught in the stem when you press it down and it results in a horrible untypable feel.
Offline Hypersphere
« Reply #4 on: Sun, 15 September 2013, 16:43:19 »
Is this based on trying the spacebar spring on 1X keys, or did you try springs from some other source?
Offline Sniping
« Reply #5 on: Sun, 15 September 2013, 16:53:48 »
The spacebar spring fits on the 1x keys, so all you have to do is find similar springs. I've tried some other springs but they all weren't of the right size.
Offline sth
  • 2 girls 1 cuprubber
« Reply #6 on: Sun, 15 September 2013, 17:08:34 »
if you locate a source for these i would participate in a group buy if you have to order a large quantity.
Offline Hypersphere
« Reply #7 on: Sun, 15 September 2013, 18:12:01 »
Thanks! If it came to a GB, I hope someone who knows how to organize such things might step in. Anyway, still looking for sources for the springs.
