Author Topic: recommend a footpedal  (Read 3870 times)
Offline gameaholic
« on: Sun, 15 September 2013, 13:56:40 »
As the title says.  I'm looking for a pedal to use for Push To Talk while I'm gaming.  Maybe some other stuff too.  Does anyone have any experience with the stinky foot pedal or frag pedal?
http://www.stinkyboard.com/
http://www.gamingmouse.com/
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Offline FoxWolf1
  • 154
Re: recommend a footpedal
« Reply #1 on: Sun, 15 September 2013, 14:49:28 »
I don't do foot pedals, but I did have an Omnimouse, which is based on the same technology as the Fragpedal. The IDI system is really powerful, and it can be fun trying to explore what it can do. Customer support from GWS is also very good. Build quality on the Omnimouse had some weaknesses, but the Fragpedal seems like it might be a more rugged creature.
Offline ijprest
« Reply #2 on: Sun, 15 September 2013, 15:36:28 »
I got my kickstarted Stinky board a week or so back.  I haven't had much time to use it yet, but I can offer some first impressions:
- It's solidly built, befitting something you're going to stomp on with your feet.
- Comes with differently-weighted springs, so you can tune it to your preferences.
- Clicky switches... (not sure what kind).
- Since it's a four-way rocker, it's really meant to be used as a replacement for WASD in FPS games.
--- Personally, I don't think I have the necessary foot dexterity to individually tap left & right buttons (singly) with any consistency.
If you just assigned one function to 'back', it'd probably be pretty good for a push-to-talk pedal.
Offline badcop
  • thorpe thocking master race
« Reply #3 on: Sun, 15 September 2013, 16:09:02 »
stinkypedal looks to be a lot of money for just PTT.  have you concidered making something like this?
http://makezine.com/video/hack-a-usb-keyboard-google-reader-pedal/
Offline gameaholic
« Reply #4 on: Wed, 09 October 2013, 10:57:27 »
I think I will get the stinky footboard.  This video shows it uses cherry mx blues.  Maybe I can throw some ergo-clears in it so I can practice not bottoming them out with my foot.  :thumb:  My next question is can you use two at the same time?  One for each foot?
« Last Edit: Wed, 09 October 2013, 11:04:24 by gameaholic »
