Author Topic: Cheap o-rings?  (Read 4751 times)
Offline uzoc
Cheap o-rings?
« on: Mon, 16 September 2013, 02:30:54 »
Trying to get extra 0-rings: 50AR, 4mm reduction (about two hundred) for my two keysets that I'm receiving.
Paid $17 + shipping for 125 o-rings, originally.
Any tips from where to get them cheaper (preferably from the US)?
Offline uzoc
Re: Cheap o-rings?
« Reply #1 on: Mon, 16 September 2013, 02:34:02 »
Found these on Amazon, but they are 0.7" in width (2mm reduction?), correct me if I'm wrong:
http://www.amazon.com/008-Buna-N-O-Ring-Durometer-Round/dp/B0051XWXCE/ref=pd_cp_pc_0
I need 4mm reduction...
« Last Edit: Mon, 16 September 2013, 02:51:27 by uzoc »
Offline terran5992
  • One With The Cup Rubber
Re: Cheap o-rings?
« Reply #2 on: Mon, 16 September 2013, 03:32:17 »
You could try IMSTO. Its in china but i dont shipping will be very expensive
http://geekhack.org/index.php?topic=33413.0
Offline gigibecali
Re: Cheap o-rings?
« Reply #3 on: Mon, 16 September 2013, 05:16:36 »
@uzoc:
Be careful what you buy. You probably need around 1mm reduction.
Cherry MX TOTAL swing is ~ 4 mm, with actuation point somewhere in the middle.
(http://www.cherrycorp.com/english/switches/key/mx.htm)
« Last Edit: Mon, 16 September 2013, 05:22:55 by gigibecali »
IBM M - UK  |  QFR reds  |  QFR blacks  |  HPE 87 browns  |  HPE 87 blues
Offline uzoc
Re: Cheap o-rings?
« Reply #4 on: Mon, 16 September 2013, 09:48:37 »
@uzoc:
Very careful, I already have them and use them with no problem.
They are probably a little less in width (I don't have a caliper) but that's what WASD keyboards calls them "4mm width".
Offline JPG
  • Model F is my new passion!
Re: Cheap o-rings?
« Reply #5 on: Mon, 16 September 2013, 09:59:03 »
These buna o-ring works very well. Also, you can get the 70A for less than 2$ a bag of 100. I use them and I love them.
Offline uzoc
Re: Cheap o-rings?
« Reply #6 on: Mon, 16 September 2013, 10:09:06 »
Where did you get them? 0.4mm?
Offline JPG
Re: Cheap o-rings?
« Reply #7 on: Mon, 16 September 2013, 10:16:08 »
http://www.amazon.com/008-Buna-N-O-Ring-Durometer-Black/dp/B003SLE5KO/ref=sr_1_1?ie=UTF8&qid=1379344408&sr=8-1&keywords=buna+o-ring+008
They are buna o-ring, size is 008 (3/16, 5/16, 1/16). They are 70A durometer, but I like it a lot. Reduce noise enough while not making the bottom out too soft.
At this price, try them and see if you like em or not. Else, well IMSTO's are probably yo best bet if you want 50A or less.
Offline uzoc
Re: Cheap o-rings?
« Reply #8 on: Mon, 16 September 2013, 10:34:43 »
Thanks, I'll try them, what I hate it that I'm going to have various ones until I can guess which ones are 0.4mm!
Offline JPG
Re: Cheap o-rings?
« Reply #9 on: Mon, 16 September 2013, 10:41:34 »
google!
1/16 inch = 1.5875 mm
Offline uzoc
Re: Cheap o-rings?
« Reply #10 on: Mon, 16 September 2013, 10:58:12 »
I think I got it...
There are three that are 3/16 (inside diameter), of the three, the different widths are:
0.07"   ~ 0.177 mm,
0.103" ~ 0.206 mm
0.139" ~ 0.359 mm
The last one being the closest. to 0.4 mm.
I'm going to get 2 of the last and 1 of the first just in case!
Hope this helps people who are trying to figure it out.
While I'm at it, I'll order a caliper to measure them.
« Last Edit: Mon, 16 September 2013, 13:39:47 by uzoc »
