Author Topic: Shrapnel's QFR Custom Cover Build Log!  (Read 7451 times)
Offline shrapneL
« on: Mon, 16 September 2013, 12:55:41 »
Alright! So first off I want to thank Jixr for his awesome painting tips. http://geekhack.org/index.php?topic=47959.0 Go check it out if you are new to painting covers!
 So to start off:
Using Jixr's tips as guidelines, I purchased 600, 1500, and 2000 grit sandpaper. Also, you can see that my first project was going to be painting my cover white.
Here's the beginning of the sanding with the 600 grit.
Skip a few steps (I'll make sure to document them with my next cover), and here we are at the end!
I really wanted to do a white case to show off Bunnylake's Miami keyset. I think it turned out great for my first attempt at painting!
I am currently working on another case right now, and it should be a banger! I will definitely post some pics as I go along this time! :)
« Last Edit: Mon, 23 September 2013, 13:39:27 by shrapneL »
hello.
Offline AlexJP
Re: Shrapnel's QFR Custom Cover Build Log!
« Reply #1 on: Tue, 17 September 2013, 19:15:38 »
Hi there Shrapnel,
How did you got this QFR case? I really need one..
thanks.
« Reply #2 on: Tue, 17 September 2013, 20:59:25 »
Hi there Shrapnel,
thanks.
http://geekhack.org/index.php?topic=47471.0
Offline shrapneL
« Reply #3 on: Mon, 23 September 2013, 17:31:43 »
Hopefully I should have an update tomorrow for my next cover that I'm working on.
hello.
Offline Tym
« Reply #4 on: Mon, 23 September 2013, 17:34:32 »
Looks great dude, so does your lawn, mines covered in dog pee stains :'(
Offline shrapneL
« Reply #5 on: Mon, 23 September 2013, 18:11:04 »
ha! It was the only place at the time that had decent lighting -_-
hello.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #6 on: Tue, 24 September 2013, 01:34:16 »
Hi there Shrapnel,
thanks.
the qfr top cases will be available internationally quite soon via the geekhackers store (temporarily located here: http://geekhack.org/index.php?topic=48030.0
Offline shrapneL
« Reply #7 on: Wed, 25 September 2013, 14:13:59 »
Here's what I'm planning for cover #2. I'm planning on doing a two tone blue fade :D Hopefully the paints work out okay for me.
And as promised, here are pics of the cover after doing the initial 600 and 1500 grit sanding.
hello.
Offline shrapneL
« Reply #8 on: Fri, 27 September 2013, 15:46:16 »
Another update! After a few days of spraying the first color, here are the results.
I'll be starting the other color tonight. :D
hello.
Offline Artichoke
« Reply #9 on: Fri, 27 September 2013, 15:51:20 »
Wow, that looks like it is going to turn out really nicely. Have any plans on what color keycaps you are going to put on it?
« Reply #10 on: Fri, 27 September 2013, 16:03:21 »
That's cool man I like it!
Offline shrapneL
« Reply #11 on: Fri, 27 September 2013, 16:18:08 »
Right now I have a plain white keycap set on the way for it. But I will continually look for some other nice combos :)
Thanks! Hoping it works out how I want it to!
hello.
Offline HesterDW
« Reply #12 on: Sat, 28 September 2013, 14:08:27 »
BMW keyboard ftw! How are you planning on doing the fade?
Offline shrapneL
« Reply #13 on: Sat, 28 September 2013, 14:23:55 »
Haha, maybe not BMW in my mind :p
So I think I'm mostly happy with it right now. I'll be doing the final sanding later today. I'll post some pics as well, and then I'll talk about some things I would have done differently.
hello.
Offline Willy
« Reply #14 on: Thu, 07 November 2013, 00:28:29 »
Why on earth would you set your pearly white QFR in the grass!?! AAARRHHHGG!
QFR - Blues
Offline shrapneL
« Reply #15 on: Thu, 07 November 2013, 12:24:32 »
Hahaha, I needed some good light, and that was the only place :) No worries! I did it carefully to not scuff it
hello.
Offline Forsythe
« Reply #16 on: Thu, 07 November 2013, 13:41:05 »
I read your name is Sniper's tone.. nice project.
Offline jevvix
« Reply #17 on: Thu, 07 November 2013, 22:18:32 »
Looks good  :thumb:
Offline shrapneL
« Reply #18 on: Sat, 09 November 2013, 12:47:11 »
Thanks guys... So I really need to follow up on the second case I started. I'll try and do that Sunday or Monday, but for a quick update I'll just say that I never completely finished it. I need to do some touch ups on it, but I think it came out well.
hello.
