Author Topic: [ebay] Genovation Numeric Keypad MicroPad 623 - SOLD  (Read 5241 times)
Offline Tarzan
  • formerly known as Greystoke
« on: Mon, 16 September 2013, 13:17:59 »
This one has the DB9 connector, not sure if it can be modded to work via PS2?  $15 and free shipping.
35654-0
http://www.ebay.com/itm/Genovation-Numeric-Keypad-MicroPad-623-/161024293963
« Last Edit: Mon, 16 September 2013, 20:28:46 by Greystoke »
Offline whiskytango
  • Don't touch the trim
Re: [ebay] Genovation Numeric Keypad MicroPad 623
« Reply #1 on: Mon, 16 September 2013, 13:33:02 »
double shots?
Offline keymaster
  • Topre Revolution Theorist
« Reply #2 on: Mon, 16 September 2013, 13:34:41 »
double shots?
It certainly looks like it. $15 shipped is a steal, but you will need a converter.
« Reply #3 on: Mon, 16 September 2013, 13:43:19 »
Cool.
Offline xavierblak
« Reply #4 on: Mon, 16 September 2013, 16:03:05 »
I grabbed this, thanks for posting it. I've been looking for a  keypad that was normal sized (most keypads seem to add an extra row) and cheap. This checked both these boxes. Now I just have to decide how to hack this to work with my computer.
Offline Tarzan
« Reply #5 on: Mon, 16 September 2013, 20:28:22 »
Post some pics once you get it, let us know what the switches look like!  I don't know much about converting from a DB9 connector, but I'm sure there are people on the forum who can lend a hand.
Good luck!
Offline keymaster
Re: [ebay] Genovation Numeric Keypad MicroPad 623 - SOLD
« Reply #6 on: Mon, 16 September 2013, 20:40:24 »
http://www.genovation.com/files/623DevManual.pdf
It looks like it DOES use Cherry switches. It says tactile, so I'm guessing it uses MX Brown.
Offline Tarzan
« Reply #7 on: Mon, 16 September 2013, 20:48:05 »
That sounds right, from what I've heard of these keypads.  There are also DB9-to-USB converters available fairly cheap, that might be the easiest way to use this on a Windows PC.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=123071
Offline xavierblak
« Reply #9 on: Thu, 19 September 2013, 16:41:33 »
Got this in today. Turns out the switch type is white alps (clicky). And the keycaps are pad printed. So pretty disappointed.
But I might still use it. I did want a clicky 4x5 keypad. So even if it isn't exactly what I was hoping for it might still get some use.
Offline keymaster
« Reply #11 on: Thu, 19 September 2013, 16:56:51 »
Yes, the 632 is a membrane keypad.
Offline Tarzan
« Reply #12 on: Thu, 19 September 2013, 17:18:21 »
There are a lot of interesting keycaps available for Alps, if you want to update the look a bit.  And I believe you can swap Matias switches in for Alps, their quiet click versions are pretty sweet (and cheap).  Of course, you can also mod clicky Alps switches to non-clicky (linear) versions.
Offline xavierblak
« Reply #13 on: Thu, 19 September 2013, 22:00:31 »
Who sells alps keycaps? I took a quick look around and all I saw was Signature Plastics selling a red esc key.
Edit: I took a few photos.
« Last Edit: Fri, 20 September 2013, 00:36:21 by xavierblak »
« Reply #14 on: Fri, 20 September 2013, 07:11:51 »
That is a really nice looking unit!!
Offline Tarzan
« Reply #15 on: Fri, 20 September 2013, 08:05:22 »
I was thinking more of Alps caps from donor keyboards, I've accumulated quite a few from old Toshiba laptops, for example.  Although the double-shot caps you have on the keypad already look quite nice!
Offline xavierblak
« Reply #16 on: Fri, 20 September 2013, 08:40:34 »
It's actually pretty yellowed. It's hard to tell from one photo but compare the top picture to the bottom. It's supposed to be the same color all the way around.
They keycaps are sadly not double-shot they are pad printed. But they don't really show any sign of wear other than some yellowing.
Offline Tarzan
« Reply #17 on: Fri, 20 September 2013, 08:49:25 »
My mistake, the keycaps look pretty nice in your pics!  I'm feeling kind of guilty, since I posted this "find," let me look around this weekend, I may have a few spare caps that would work on the keypad.
