Author Topic: Please put site's name in the html title  (Read 5477 times)
Offline Piotr Dobrogost
« on: Mon, 16 September 2013, 14:28:24 »
It would be great if html title of every page would start with the name of site which makes it possible to easily use password managers to log in.
Offline keymaster
  • Topre Revolution Theorist
Re: Please put site's name in the html title
« Reply #1 on: Mon, 16 September 2013, 14:30:10 »
Do you use LastPass? You should.
Offline domoaligato
« Reply #2 on: Mon, 16 September 2013, 15:00:19 »
I just look for the orange keycap icon on the tabs.
« Reply #3 on: Tue, 17 September 2013, 13:56:31 »
LastPass works only in browser - I'm using KeePass which works across whole OS.
« Reply #4 on: Tue, 17 September 2013, 13:57:32 »
Offline domoaligato
« Reply #5 on: Tue, 17 September 2013, 15:31:17 »
Offline Jack
« Reply #6 on: Tue, 17 September 2013, 15:39:07 »
I go to Home where the title is "geekhack" to use KeePass autotype, instead of the login page. Would be nice to have it everywhere though.
